Rear end link bolt tightening procedure/issue
Happy holidays folks.
I'm in the process of replacing the rear end links on my 87. Everything is back in place. Bolts were threaded to trailing arms by hand then quickly became VERY difficult to tighten with a 1/2" wrench setup, so tight I was afraid it may be damaging the t-arm so i quit. I feel like I was using 50+ lb-ft. The links are not binding and slide easily on the bolts. New links and hardware came from our host.
Is this normal and just the torque-to-yield process? Any insight is appreciated.
Old 12-21-2024, 02:24 PM
Never force a bolt into threads. Check and clean them, chase them if necessary.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 12-22-2024, 05:19 AM
dtwa's Avatar
Check that the bolt threads are the correct pitch. I don’t recall the details, but when I replaced my rear swaybar drop links, the new bolts supplied with the links were the right diameter, but wrong thread pitch. Same behavior you are seeing. I almost trashed the threads in one of the trailing arms before realizing.
—Best, Dave
1985 Carrera 3.2 • Prussian Blue Metallic
Old 12-23-2024, 08:57 PM
