-   -   Flag mirror 1976 - where to connect this plug? (http://forums.pelicanparts.com/porsche-911-technical-forum/1171746-flag-mirror-1976-where-connect-plug.html)
x98boardwell 12-21-2024 02:39 PM
Hello,
I have another question for the experts. I purchased this car as a project and finally getting it back together after repaint, engine rebuild and interior work.
I am unable to find this plug in the frunk area that this is supposed to connect once it travels from the door into the car. I started to look under my dash as I thought maybe it was there but my memory is telling me it connected inside the frunk.
I can't seem to find the other connection plug that matches anywhere. Could someone provide an idea of where it would be sitting so I can a better idea of where to start tearing into?
Thanks in advance! Pic below.
http://forums.pelicanparts.com/uploa...1734824326.jpg
silverlock 12-21-2024 04:29 PM
Should be near the hood hinges on the respective side of the car. Can be tucked back a bit.
x98boardwell 12-21-2024 06:10 PM
Thanks @silverlock
I was also thinking the same thing as I remembered where I detached it from but can't find it.
It would be helpful if I knew where it had come from... maybe then I could trace backwards to find it! Thanks for any additional help.
timmy2 12-21-2024 07:17 PM
Find the only violet/black wire connected to the fuse panel and follow it into a small loom towards the lower hood strut area.
silverlock 12-22-2024 06:40 AM
http://forums.pelicanparts.com/uploa...1734881884.jpg
timmy2 12-22-2024 07:39 AM
76-77 drawings: remember to count your fuses from the headlight back to steering wheel when using factory schematics. :)
http://forums.pelicanparts.com/uploa...1734885514.jpg
