-   -   993 varioram Airbox or Cone Filter? which is better (http://forums.pelicanparts.com/porsche-911-technical-forum/1172318-993-varioram-airbox-cone-filter-better.html)
jmz 01-06-2025 07:15 AM
Hi all,
I have a 993 varioram going into my IROC tribute. The engine did not come with an airbox so I either need to source one or put an aftermarket set up on.
Does anyone have any input as to which is better? I plan on running a set of Georges headers and some kind of RSR style exhaust.
Thanks,
JZ
Bill Verburg 01-06-2025 11:18 AM
Originally Posted by jmz (Post 12385684)
Hi all,
Thanks,
JZ
depending on how the engine is mounted in the chassis it can be an issue to use the stock air box
if you use the stock 993 console and cross bar the engine is low enough that the stock box w/ a modified cover fits
you can see here where I cut away part of the cover to clear the hinges
http://forums.pelicanparts.com/uploa...1736190699.jpg
if using the 3.2 console and 911 crossbar the engine sits higher so thee is more of an issue, most use a completely cut away cover
like on this one
http://forums.pelicanparts.com/uploa...1736191035.jpg
of course you can always use a cone too, but I'd rather have the stock air cleaner
jmz 01-06-2025 11:51 AM
Thanks Bill. I am using a 3.2 console. I did raise the package tray for clearance but don't think that helps the issue you mention above.
So... find a used or buy a new airbox and then cut it up. I guess that nifty mounting clamp is available from Fabspeed?
