Radio delete face plate for a 73
In my continued attempt to remove non-essential parts to my 911, I have removed the radio. So my question is this: I know someone (our host even?) makes a plate to cover up the radio but I can't seem to find one. My car is a 1973 model. Does anyone have a recommendation or a source? Thanks in advance.
1973 911 3.0 (sold)
1980 911 SC (sold)
Old 04-03-2011, 04:20 PM
Oh Haha's Avatar
Radio delete suggestions needed
Pacific Blue
Wayne
Old 04-03-2011, 04:31 PM
Oh Haha, thanks for the link. No wonder I couldn't find it in the Pelican site as it states it is for 74-89. anyone know if the faceplate fits a 73? If not I will look into a custom aluminum piece to hold my lap timer. I do like the idea to hold an iphone for the trips to the track.
Old 04-03-2011, 04:51 PM
Oh Haha's Avatar
I didn't find any for the 69-73 cars, either. I don't know enough about those years to know if the later face plate would work.
Someone here WILL know, though.
If you can, change your post title to include the car year. I think if you slect "edit" and then "advanced" it will allow the change.
Pacific Blue
Wayne
Old 04-03-2011, 04:57 PM
Thanks for the suggestion.
1973 911 3.0 (sold)
1980 911 SC (sold)
Old 04-03-2011, 06:45 PM
Hi,
The original radio delete plate for a 69-73 is very hard to find, almost impossible. You might try Edmond Harris in the UK. Simple solution is to cut a piece of thin metal (around 0.75 mm) exactly to size and glue correct vinyl on it. Slide it in from the glove box side. There is someone on eBay (search for Porsche Radio Delete plate) that make reproduction plates.
Regards, Cees
Old 04-03-2011, 07:46 PM
Here you go...
Porsche 911 912 Radio Dash Panel Delete Blaupunkt DIN - eBay (item 360355613088 end time Apr-04-11 12:24:36 PDT)
I purchased one for my 73 911 and it fits perfectly....
Mark
Old 04-03-2011, 09:57 PM
joefrantz's Avatar
One of the problems with a '73 is that the matching vinyl for the dash insert is NLA.
I got something similar from Tony at Autobahn, but when you put the two side by side, there is a visible difference. To get a consistent match you'll need to replace all of the insert vinyl.
I replaced all of mine, but I also don't have heat, so that control panel was already gone, along with the radio. Working with the heater controls. ignition and light switches is a pain. They've got to come out before you can remove and re-cover the inserts.
A decent looking "delete" plate or re-using the space for something else would eliminate the vinyl matching issues.
Joe Frantz
73 911 T
Old 04-03-2011, 10:36 PM
Thanks for all the input ... It gives me some options.
Old 04-04-2011, 12:49 PM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
make your own... i did from parts floating around the garage.
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 04-04-2011, 01:09 PM
be here now
R K T's Avatar
Here's a pic of mine. I deleted just about everything!
Rob....
Old 04-04-2011, 04:28 PM
I ordered one from the dealer a few years back. It took a while to get. Better option is to make your own.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 04-04-2011, 06:52 PM
Honda OEM Single DIN Radio Block Off | Password JDM
is this what you are looking for?
Old 04-04-2011, 10:07 PM
kramer747's Avatar
because the radio is SO heavy it must be deleted! Seriously? This isn't nascar
Old 04-04-2011, 10:29 PM
boooooooooooooo nascar. yeaaaaaaa rally!
Old 04-04-2011, 10:31 PM
be here now
R K T's Avatar
Who wants to listen to a stupid radio when you've got the Porsche orchestra playing in the back?!?
Rob....
Old 04-05-2011, 05:02 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
Exactly. Ive never understood while Porsches even come with a radio to start with.
Old 04-05-2011, 12:48 PM
Who said anything about weight savings? I think the term was non-essential parts! In any case, thanks for all the suggestions.
Old 04-07-2011, 06:49 PM
bjf bjf is offline
I bought a rain delete panel on ebay for my 73. Does anyone have a pic of the delete panel out so I can see how I should put the vinyl on?
Old 01-13-2025, 04:05 PM
E Sully's Avatar
Contact cement works great for attaching vinyl.
Ed
1973.5 T
Old 01-14-2025, 04:07 PM
