Wiper Potentiometer switch - connections
Where do the 3 small wires plug into on the back of the wiper delay switch?
I have Black, Red and Red/Yellow wires. Connections: 15a - 15 - 15b -
what car? Where is this located...I can look at mine nd take a pic
https://forums.pelicanparts.com/porsche-911-technical-forum/1100267-sc-wiper-switch-potentiometer-wiring-diagram.html
Likely depends upon your model, year, etc. but here's a start.
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you. |
It’s a 1980 911 SC.
Thanks for the link. |
Is there a diagram on one of the surfaces?
IIRC, it's a panel mount 100K logarithmic potentiometer with an on/off switch. Log pots are pretty common in audio applications, so not hard to find one if you need to.. Some might even accept the factory knob/cap. Quote:
RoninLB posted this current flow diagram, post #8 in this thread: Intermittent wipers on an early 911. E38 is the intermittent pot.
'77 S with '78 930 power and a few other things. |
Used info from link provided by Synchro Joe and it works as designed.
Here are the connections: 15a- Red/Yellow 15 - Red 15b - Black |
