Porsche Crest Andial Deep Sump coating
I'm wanting to refinish and update my Andial Deep sump.
I was thinking about sending this to Jet Hot, as I have had a few exhaust systems done in the past
But I am sure there have been a lot of changes made in the coating industry so any help would be greatly appreciated.
I am also going to see if I can update the hoses to Earls.
Merry Christmas and thanks in advance.
Old 12-25-2021, 08:16 AM
Arlo911's Avatar
I´d have it Cerakoted.
Old 12-25-2021, 08:58 AM
For the Cerakote, I would use an oven cured heat dispensing version. The oven cured version is more durable.
That's an interesting deep sump does it use a deeper/longer pickup tube?
Old 12-25-2021, 09:19 AM
https://swaintech.com/
Old 12-25-2021, 09:20 AM
Thanks, I'll have to check about the pick up tube..
Old 12-27-2021, 07:17 AM
Evan Fullerton's Avatar
Anyone know the history on these? Is is supposed to help head drain back with the extra tubes to the sump from the return tubes? Seems like a strange piece on a dry sump motor.
Old 12-27-2021, 09:37 AM
Look out for speed bumps!!!
206 637 4071
Old 12-27-2021, 09:39 AM
Cerakote.
I would shear something like that off where I drive.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 12-27-2021, 09:40 AM
Originally Posted by evan fullerton View Post
anyone know the history on these? Is is supposed to help head drain back with the extra tubes to the sump from the return tubes? Seems like a strange piece on a dry sump motor.
racing97 racing97 is offline
registered
this was part of a package that jim busby developed while andial were doing the engines for his 1975 rsr. It was to remove the proximity of the oil from the crankshaft to prevent centrifical gathering of the oil mass around the crank. It also was run in conguntion with one way gulp vlaves (2) positioned in the header collector to create crank case vaccum. I think jim mcfarllin was the mentor in this exercise. I forgot pete ingcognuto made angle port inserts for the heads that tended to straighten out the ports, it was quite a eleborate modification with a schrick cam. After it was all said and done and worked the parts were labled with the andial logo.
:d
Old 12-27-2021, 12:15 PM
Originally was going to use on this, but this one is going into the 914-6GT clone.
When we rebuild my 78 SC, was thinking this would be cool.
Old 12-27-2021, 05:15 PM
Here was a Porsche solution, I think 935.
Old 12-28-2021, 10:15 AM
Very cool, thanks for sharing.
Old 01-02-2022, 06:16 AM
It’s good quality aluminum. I would not be to worried about corrosion. All andial applied was black heat paint. Don’t coat the internals and don’t use a coating that will insulate it. It’s supposed too dissipate heat .
We have ours on the 2.3L race motor together with a Glenn Yee Motorsports oil pump.
A large reduction of crankcase mist in the 7-9000rpm range.
Old 08-05-2022, 02:15 PM
true meaning of Deep Throat Sump
The deep sump came about in the early 80,s in Imsa for the RSR cars.Back then we did not run valve guide seals.The standard oil breather cover was replaced with a fabricated unit that was about 6 inches high with 3 hose fittings.One went to the oil tank and the other 2 were connected to a hose that ran to the collector that installed at a 45 degree angle.Designed to pull crankcase vacuum for more free revving.The oil return tubes dropped the oil to the ANDIAL deep sump.The objective was to keep the oil from building up in the lower valve cover and being sucked through the exhaust guide in a long fast turn.Ran these for about 2 years then IMSA banned them because with a motor with wear it became a mosquito killer and vision behind the car was compromised.It did rev better though.I forget how many inches of vaccum it pulled.Worth a couple of ponies higher up. Fred
Old 08-05-2022, 03:05 PM
Nick named the tower of power !
Old 08-05-2022, 03:59 PM
I really need to get going on this.
Old 01-19-2025, 11:17 AM
