 I wonder if there is merit to the original having a bit of an angle. Trying to install the Dansk, I was uncomfortable with the fit. Gasket in, installed the sender and could definitely tell it was "hitting/tapping" the bottom as I moved it around a bit. Also, the threaded/small nut part extended quite a bit beyond the base of the sending unit. Wasn't comfortable with the possibility of it touching/rubbing so I got rid of and reinstalled the original for my cross country. My original this threaded area was recessed into the base... Used the trip odometer which, of course, works...but still want to remedy my fuel sender issue... Sorry for the late update but for me the Dansk didn't work. Erik |
 Well, I ditched the Dansk and went with a URO sender. Just installed and it seems to be working. I did have an issue initially in regards to it not reading the level. After I installed, then removed the unit from the tank, I carefully tilted back and fourth a few times to let the 'float' move back and fourth. Seemed to work. Filled the tank up and it shows full...so, so far so good. I was seconds away from ordering from the dealer, but have had good luck in the past with URO products and thought I would give it a go. I am now more in the habit of using the trip odometer so will see how things go. Hopefully, I finally get a reading below 1/2 to 1/4 of a tank...that has been my issue the last year...I will post back in a few months. Erik |
 @UROParts  Do you have a picture of the shipping lock pin in place, and how to remove it? I might have the same issue on mine. Cannot find a picture or instructions to remove this anywhere on the internet. Thanks!  Quote:
 One month with the URO fuel sender and all is well.  Drove 500-600 miles and it worked well with a few fill ups... Just an FYI.... Erik |
 http://forums.pelicanparts.com/uploa...1746836790.jpg |
 Thanks for your reply and willingness to help. The sender that I got a couple of years ago was not a URO sender. |
| All times are GMT -8. The time now is 05:10 PM. |
