O-Ring for Front Wheel Spindle
Hi,
this is my first post, I have an 87 911 carerra, I installed front wheel bearings and can't figure out how to install the O-Ring for Front Wheel Spindle. When I removed drivers side it did not have the part and the other side it fell out before I could see where it went. All on-line video's and instructions don't mention this part. It is a small black rubber ring about the size of a Quarter. Maybe I don't need it? Thanks for any help Squid |
Squid,
First, welcome to the Forum ![]() You will find a lot of help here. Here is an image of an earlier spindle but basically the same as yours. The O-ring goes behind (green arrows) the seal race and over the spindle. ![]() The seal race is removed with a standard (Harbor Freight) inexpensive 2-jaw puller. The spindle and new O-ring should be covered with grease under and behind the seal race. When reinstalling the seal race, heat it to about 150F and it will slide on a cold spindle. Be sure to seat the seal race with a pipe-tool and hammer. Never use the bearing tightening to seat the seal race. If you have more questions, be sure and ask. The only ‘dumb question’ is the one un-asked. ![]() Again, WELCOME! Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Thanks for the help but I don't think we're talking about the same o-ring, the diagram shows this o-ring on the spindle. How could it fall out in tact when I never removed the spindle
Porsche 911 & Carrera Axles & Bearings - Page 3 |
![]() before I tackle , any tricks, info, I can use to get the o-ring/race back on?
1970 T Tangerine sold 1972 T Albert Blue Last edited by Fastdog911; 03-10-2014 at 09:44 PM.. |
[QUOTE=Fastdog911;before I tackle , any tricks, info, I can use to get the o-ring/race back on?[/QUOTE]
1- Clean to shiny metal all parts 2- The spindle and new O-ring should be covered with grease under and behind the seal race. (install) 3- When reinstalling the seal race, heat it to about 150F and it will slide on a cold spindle. (place the steel seal race in a metal pan and fill with motor oil to cover the race. Place in oven @ 150 for one hour to heat.) 4- Slide hot oiled race over spindle, the race will all but fall on/over the spindle. 5- Be sure to seat the seal race with a pipe-tool and hammer. (I have used a short piece of pvc plumbing pipe to use as a "pipe-tool" to tap the race firmly to the spindle seat, it won't take much.) 6- Clean up wife's kitchen pan before she finds out Never use the bearing tightening to seat the seal race. |
Spiderman
Appreciate this post
Just asking, how important is it to pull the seal race and replace? By that I mean, does it only need to be pulled and serviced/replaced if there is a groove that would impair the seal from functioning? ie, seeing dirt or rust getting to the bearing ?
I've never pulled this race when servicing my brakes or bearings, its always looked very good to my eyes. Thanks
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Thanks so much for help! Here is a photo of part # 901 341 623 00 the back side has a taper to allow fitting for o ring.... o ring is 999 701 084 50/104 Thanks again!
1970 T Tangerine sold 1972 T Albert Blue |
Great information. Thanks to everyone!
Did mine just a few weeks ago, maybe these are of some help as well:
79 911SC sunroof Coupe (ROW) |
