Blackbyrd's Avatar
Helping finding 1989 Clubsport gear ratio
I have clubsport service book and it didn’t list the ratios
I have the euro parts catalog and see only 5th gear ratio changing
Does anyone know a definitive clubsport G50 gearbox ratio ?
Thank you in advance
Follow me on Instagram: efrenporsche
Old 01-25-2025, 07:28 PM
Bill Verburg's Avatar
3 g50 versions
g50.00 RoW
g50/01 US ,Can.& Aus
g50.03 Switz.
each had M220 LSD option
I see that 5th was changed for '88 up from 31:36 to 33:36 for '88m up RoW
and from 32:36 to33:37 on the others
no reference at all to M637 changes to the trans, just to engine suspension and chassis(mostly interior parts
Bill Verburg
Old 01-26-2025, 11:13 AM
gearhead
Clubsports have no special ratios.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 01-26-2025, 11:52 AM
Blackbyrd's Avatar
Thank you both
Great contributors
I did hours of searching and came up with the same
Conclusion
Everywhere I read and see (videos) everyone says “close gear ratios for clubsport”
Including UK magazines where they already had shorter gears on normal Carreras
But no one says what those gears are
The parts catalog only changes 5th and they get taller and taller
I see ROW is short compared to USA and the 5th going up in teeth must have been for economy
I went as far back on the forum and didn’t see any other reference for M637/Clubsport
Maybe the USA didn’t have special gearboxes but how about the Euros ?
Is there a definitive way to tell ?
Old 01-26-2025, 01:49 PM
Thank you both
Great contributors
Conclusion
No M897 anywhere wrt trans except for a short throw shifter
.00 RoW: engine turns 2.966 per 1 wheel turn turn in '87 and 2.991 in '88
.01 US, Cdn, Aus: engine turns 3.062 per 1 wheel turn in '87 and 3.072 in '88
.02 Switz.: same as US
Biggest difference seems to be US market still had full under coat
and a funky rear seat delete that added weight to US CS
US CS weight before Porsche Cars NA decided to keep full undercoat was 2601#(155# less than a US Carrera. Row w/o undercoat was 2557#
GB CS seem to have similar weight handicap to US versions
Bill Verburg
Old 01-26-2025, 02:41 PM
