Got the new lines swapped. Took her for a little drive and have no leaks. Also seems like the thermostat was working again. Maybe since the oil pressure with non leaking lines was better? Drove for 20 minutes and sat idling at a friends house and it never rose over the first temp line. Side lines were warm/hot feeding the oil cooler in the fender. Seems all good…for now.
Thanks everyone!
Lucille my ‘85 guards red 3.2 |
Great, thanks for the update. Always good to get closure on a problem.
Mine only opens once the reading on the gauge has reached nearly 9 o'clock. See the pic I posted on previous page. That is only at that reading on the gauge that I can feel both lines are getting hot along the side of the car. I begin to wonder if my external thermostat is failing. What do you people think? Is this far too late for the external thermostat to open? Sorry to hijack.
Gilles RoW 88 Carrera coupé Last edited by wazzz; 02-02-2025 at 03:30 AM.. Reason: typo |
@Gilles
I would check at first the temp sensor if this is the right one matching to car and gauge. Then check the electrical connections / contacts, esp. ground. The oil thermostat from the external oil cooler in the rear right fender is a Behr TO-282 with an opening temperature of 83°C/181°F More reference numbers of the thermostat: MAHLE - 1.249.83 / 124983 MAHLE - 70807743 / 70807743 MAHLE - 70809114 / 70809114 MAHLE - TO 2 83 / TO283 PORSCHE - 930 107 155 00 / 93010715500 PORSCHE - 930 107 755 00 / 93010775500 If the temp gauge reading is correct your engine seems to run too hot. IMO mostly a wrong ignirion timing may cause this as it happened to.my SC. but yours is a Carrera with ignition timing being managed by the Motronic. Maybe it runs a bit too lean??? Check the mixture. Thomas Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 02-02-2025 at 04:18 AM.. |
Thanks Thomas. This has been going on for a few years now. Everything is stock on my car. Never changed external thermostat or temp sensor, so they are the same as when they left the Porsche factory. Checking the temp sensor is a good idea. However, right now with cold ambient temps my car runs cold, I mean the needle never go past what I think should be more or less 80°C, that is 3 or 4 mm before first line on temp gauge. This is the maximum I can get even when driving several hours at legal speeds (130 km/h).
This 9 o'clock situation only occurs on hot summer days when ambient temp is around 30°C or over. But I'm pretty sure it never did that a few years back. The underside oil lines used to get hot at a lower temp reading. This is why I suspect a failing external thermostat. Is it possible that it binds and only opens at a higher than nominal temp? Thanks.
Gilles RoW 88 Carrera coupé |
When your car didn't do it earlier something has changed. Check the oil lines going to front oil cooler when car is barely driven 2-3 mls...if they are already getting warm too these colder days, the thermostat may have stuck somewhere in between and remains open all the time. Then this may be the culprit... Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
