3.2 Carrera Engine Mount Bolt size?
Hey guys,
I need to replace the 4 engine mount bolts in my 3.2 Carrera.
Does anyone know what size those 4 bolts are for the engine mounts (2 on each side)?
Looks like all four of mine are missing! 😳
Old 01-31-2025, 08:43 PM
A930Rocket's Avatar
#14?
M 12 X 1,5 X 95
Old 01-31-2025, 08:55 PM
A930Rocket's Avatar
Or #9?
M 8 X 35
Old 01-31-2025, 08:57 PM
Or #9?
M 8 X 35
Yeah the two side bolts on each side, #9.
I thought they were M12 x 35mm?
Old 01-31-2025, 08:59 PM
H-viken's Avatar
The four bolts are not identical! Two different types
You say all four are missing. That sounds odd. Can you share some pictures?
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 01-31-2025, 09:08 PM
The table above shows #9 requires four M8 x 35mm bolts.
Will post a pic when I’m back home 👍🏼
Should spring washers be used here too in order to minimise loosening due to vibrations?
Old 01-31-2025, 10:06 PM
Both sides are missing these bolts!
Old 01-31-2025, 11:43 PM
Ahh…. So you need items 9, 10 and 11 from the first image
Old 02-01-2025, 12:12 AM
Yup! All sorted this evening 😎👍🏼
Old 02-01-2025, 02:07 AM
H-viken's Avatar
Pictures win again
911E Coupe -70
Old 02-01-2025, 02:38 AM
