3.2 Carrera heater crossover pipe
Hey guys,
Does anyone know the outer diameter of the heater crossover pipe between heat exchangers on the 3.2 Carrera heat exchangers? Is it 3” OD? I’m considering using this heater crossover tube for my 993TT heat exchangers, with some minor modding to make it fit. Thoughts? ![]() Pic of my heat exchangers whilst its on a hoist: ![]() Last edited by 911TT33; 02-04-2025 at 01:06 AM.. |
That Guy
Its closer to 2.5" OD. That is the size of scat tubing i bought a few years ago to connect everything.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
I just happen to have one handy. Let me know if you need any other measurements.
I think that’s 65mm too. The 993TT heat exchangers have a 3,0” OD port. Might have to use a reducer to interface them or modify the Carrera crossover pipe by flaring it from 65mm OD to 75mm OD. |
Counterclockwise?
You might have to cut it to fit the headers like my B&B's.
I'm trying to find the orange ones. ![]()
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
My fabricator will definitely need to flare out the pipe ends from 65mm to 75mm so it mates properly. Are these crossover pipes aluminium or SS? I don’t have it in hand to check. Ordered one off eBay. |
Counterclockwise?
Not aluminum, I thought regular steel, but I'll check.
Counterclockwise?
Yup SS. I checked.
Thread Tools | |
Rate This Thread | |
