-   -   911sc 3.0 1982 Engine Harness source (http://forums.pelicanparts.com/porsche-911-technical-forum/1173877-911sc-3-0-1982-engine-harness-source.html)
ukinusa 02-12-2025 05:06 PM
Just pulled my 911sc engine . 1982 3.0.
The wiring has been butchered and messed with and there are some burnt wires; the engine started and seemed to run fine before I took it out. I think it's time for new sub harness - engine harness. Multiple sources and multiple prices - any suggestions please ?
Also should the car have an oxygen sensor ? books says it should but nothing to be found - just a cut green wire :confused:
http://forums.pelicanparts.com/uploa...1739408673.jpg
silverlock 02-12-2025 05:29 PM
‘82 SC’s had oxygen sensors, although they are not required to run (open loop mode).
Harness should be 911.612.016.04 for an 82-83 car.
http://forums.pelicanparts.com/uploa...1739410152.jpg
silverlock 02-12-2025 05:31 PM
https://911-manuals.questionable.services/porsche-pet-911-sc.pdf will be your best friend.
Flat6pac 02-12-2025 05:37 PM
You still need to hook up the lambda control under the passenger seat.
The connector behind #3 intake should plug to the harness inboard the left rear shock.
Your pre lambda cat replacement not showing tap for ox sensor.
I have replacement cat pipes if you decide you need the sensor installed.
Bruce
spoke 02-12-2025 07:31 PM
Multiple sources and multiple prices - any suggestions please ?PXL_20250211_2136282231739408673.jpg[/img]
Timmy2 (Dennis) just made a new harness for my '86 930. It is a thing of beauty.
He even fitted the much larger alternator cable that came with my 175A Classic Retrofit alternator.
http://forums.pelicanparts.com/uploa...1739417410.jpg
gerakroo 02-12-2025 11:53 PM
https://www.kroonwireharnesses.com/porsche-911/porsche-911-1982/wire-harness-for-engine-sc-82-83
We can also deliver it in a "HI version"
https://www.kroonwireharnesses.com/porsche-911/porsche-911-1982/engine-harness-for-porsche-911sc-82-83-artno-91161201604hi-upgraded-25mm2-alternator-wire-for-high-output-alternators-
gamin 02-13-2025 01:08 PM
Timmy2 (Dennis Powell) makes fantastic harnesses. Custom harnesses too. Almost all the harnesses in my '70 are from him. Some are custom. Car wouldn't be running without him. Easy to talk to.
ISGASA 02-13-2025 01:28 PM
I just received a harness for my 81 SC from Timmy2. Very good craftsmanship.
al lkosmal 02-13-2025 06:17 PM
dennis (Timmy2) makes all of the harnesses for my EFI kits....good stuff.
99boxster559 02-13-2025 07:57 PM
+1 on Dennis. He got me setup on a harness for my 82SC. Same situation you are in now. Great fit and finish with all wires labeled was a plus!
Jeff Alton 02-13-2025 09:22 PM
Look up Restoration Design. They have what you need all to OE spec.
ukinusa 02-28-2025 09:14 AM
Thanks Jeff - sourced from Restoration -- met them in LA - it was on special too !!!
