911sc 3.0 1982 Engine Harness source
Just pulled my 911sc engine . 1982 3.0.
The wiring has been butchered and messed with and there are some burnt wires; the engine started and seemed to run fine before I took it out. I think it's time for new sub harness - engine harness. Multiple sources and multiple prices - any suggestions please ?
Also should the car have an oxygen sensor ? books says it should but nothing to be found - just a cut green wire
Old 02-12-2025, 05:06 PM
‘82 SC’s had oxygen sensors, although they are not required to run (open loop mode).
Harness should be 911.612.016.04 for an 82-83 car.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings)
Dynamic CR calculator: https://dcr.questionable.services/
Gear Ratio (Speed @ RPM) calc: https://ratio.questionable.services/
Old 02-12-2025, 05:29 PM
https://911-manuals.questionable.services/porsche-pet-911-sc.pdf will be your best friend.
Old 02-12-2025, 05:31 PM
You still need to hook up the lambda control under the passenger seat.
The connector behind #3 intake should plug to the harness inboard the left rear shock.
Your pre lambda cat replacement not showing tap for ox sensor.
I have replacement cat pipes if you decide you need the sensor installed.
Bruce
Old 02-12-2025, 05:37 PM
spoke's Avatar
Multiple sources and multiple prices - any suggestions please ?PXL_20250211_2136282231739408673.jpg[/img]
Timmy2 (Dennis) just made a new harness for my '86 930. It is a thing of beauty.
He even fitted the much larger alternator cable that came with my 175A Classic Retrofit alternator.
Find Spoke's LED Products:
www.spokeworksled.com
Old 02-12-2025, 07:31 PM
Kroon Wire Harnesses
https://www.kroonwireharnesses.com/porsche-911/porsche-911-1982/wire-harness-for-engine-sc-82-83
We can also deliver it in a "HI version"
https://www.kroonwireharnesses.com/porsche-911/porsche-911-1982/engine-harness-for-porsche-911sc-82-83-artno-91161201604hi-upgraded-25mm2-alternator-wire-for-high-output-alternators-
Specialized in Classic Porsche electrics
Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses
Old 02-12-2025, 11:53 PM
Timmy2 (Dennis Powell) makes fantastic harnesses. Custom harnesses too. Almost all the harnesses in my '70 are from him. Some are custom. Car wouldn't be running without him. Easy to talk to.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 02-13-2025, 01:08 PM
I just received a harness for my 81 SC from Timmy2. Very good craftsmanship.
Old 02-13-2025, 01:28 PM
al lkosmal's Avatar
dennis (Timmy2) makes all of the harnesses for my EFI kits....good stuff.
RGruppe #669
http://www.x-faktory.com/
Old 02-13-2025, 06:17 PM
+1 on Dennis. He got me setup on a harness for my 82SC. Same situation you are in now. Great fit and finish with all wires labeled was a plus!
Old 02-13-2025, 07:57 PM
Jeff Alton's Avatar
Look up Restoration Design. They have what you need all to OE spec.
www.turn3autosport.com
Old 02-13-2025, 09:22 PM
Thanks Jeff - sourced from Restoration -- met them in LA - it was on special too !!!
Old 02-28-2025, 09:14 AM
