Drilled exhaust stud - did I go too far?
Hi everyone,
Looking to get some advice regarding an exhaust stud that snapped while converting to SSIs on my 1983 911SC. After the stud snapped I bought the Stomski kit to drill it out. Unfortunately, while drilling with the 3/16” bit I believe I drilled too far. I compared a stud hole with the stud removed to the hole I drilled and found that the hole I drilled was about 15mm longer. I did a better job with the 17/64” bit and drilled it to almost the exact same length as the empty stud hole. But what did I drill into with the 3/16” bit? Is my engine damaged? Pics below for reference.
Old 04-05-2025, 07:37 PM
Registered Minimalist
75 911s's Avatar
In my opinion you are fine. I've seen drilling beyond that point and it usually just hits a fin and not the all important head chamber where combustion takes place. You should be good. I would test with a new exhaust stud and see if it's level with the existing studs - at least when you go to tap out the new hole.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 04-06-2025, 11:33 AM
PCA Member since 1988
Concur with 75 911s. If you pour liquid into the hole, and it doesn't drain out, you did not go too far.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-06-2025, 09:57 PM
You should be fine.
You're not the first this happened to.
Old 04-07-2025, 04:33 AM
Thanks guys! I was about to have a heart attack!
Old 04-07-2025, 01:17 PM
