-   -   911SC rear Targa window install question (http://forums.pelicanparts.com/porsche-911-technical-forum/1174680-911sc-rear-targa-window-install-question.html)
GTT 03-03-2025 08:01 AM
Question for those of you that have tackled the rear Targa window installation. I've read multiple threads on this and was able to get my rear Targa window reinstalled after a respray using the ratchet strap method (highly recommended for anyone attempting to replace the rear window and seal).
Question I have is, once it is installed, do I need to use a bedding compound between the rubber seal and the metal/glass? I've seen at least one thread where someone used 3m 08509 Bedding & Glazing Compound, but haven't seen any other comments about it. It seemed like there was some compound under the seal when I removed the window originally, which I assume may have been original.
WMichelsen 03-03-2025 11:53 AM
On recent removal of the rear Targa glass from my '87, it did not have any additional sealant. Having said that, the glass was R&R'd by a body shop 20 years ago. It's possible they deviated from factory, but I doubt it.
Interested here because I will be reinstalling it relatively soon.
GTT 03-20-2025 02:36 PM
WMichelsen, I just got my hands on a set of factory workshop manuals and looks like the factory calls for a sealing compound. 3M apparently doesn’t make 08509 anymore, but I read some threads about a substitute called CRL7708 Windshield and Body Sealant. Found it on Amazon so that’s what I’m going to use.http://forums.pelicanparts.com/uploa...1742506600.jpg
