Rear bumperette part numbers L&R diff?
I have an 85 911.
I bought a used PASS side bumperette from another '85 , part # 911 505 342 02, which DID NOT FIT. Bolts lined up but it did not fit the contour of my bumper. The part # on mine is 930 505 032 01 Is the left side the same part # or different? Didn't want to risk taking off the drive side to check...the studs are prone to breaking. I thought there were only 2 styles...Euro and US. Wow I was very wrong!! |
Because the license plate lamps mount to the "inside" of the US-spec bumperettes, and because the bumperettes have a specific top & bottom surface profile, the R&L parts are mirror image.
In the Porsche part numbering world, The third 3 digit set indicates side, that is even numbers are right side and odd numbers are left. So a 341 would be driver side. |
part number
my right side part number is 930 505 032 01, which is off the car. would the left side be
930 505 031 01. or 930 505 033 01 need a 930 505 032 01 thanks! Quote:
yes, found that. thank you!! so expensive...not surprised
| All times are GMT -8. The time now is 12:35 AM. |
