Rear bumperette part numbers L&R diff?
I have an 85 911.
I bought a used PASS side bumperette from another '85 , part # 911 505 342 02, which DID NOT FIT. Bolts lined up but it did not fit the contour of my bumper.
The part # on mine is 930 505 032 01
Is the left side the same part # or different? Didn't want to risk taking off the drive side to check...the studs are prone to breaking.
I thought there were only 2 styles...Euro and US. Wow I was very wrong!!
Old 03-03-2025, 10:53 AM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
Because the license plate lamps mount to the "inside" of the US-spec bumperettes, and because the bumperettes have a specific top & bottom surface profile, the R&L parts are mirror image.
Old 03-03-2025, 11:20 AM
Shaun @ Tru6's Avatar
Originally Posted by jgurnari View Post
I have an 85 911.
91150534202 is for 75 to 81 911s so it won't fit your 85.
In the Porsche part numbering world, The third 3 digit set indicates side, that is even numbers are right side and odd numbers are left. So a 341 would be driver side.
Tru6 Restoration & Design
Old 03-03-2025, 11:31 AM
part number
my right side part number is 930 505 032 01, which is off the car. would the left side be
930 505 031 01. or 930 505 033 01
need a 930 505 032 01
thanks!
Old 03-03-2025, 12:49 PM
031
https://www.pelicanparts.com/More_Info/93050503101.htm?pn=930-505-031-01-OEM&srsltid=AfmBOoqIo0-fOjn0clZ_tSy85IAdkxqtEEIYG0L15eIFl8x_1UIM26oQ
Old 03-03-2025, 01:04 PM
yes, found that. thank you!! so expensive...not surprised
Old 03-03-2025, 01:05 PM
