Hole in dash next to heat controls
What was the hole for next to the heater controls? I'm trying to find a spot for my start/stop button. My other option would be to pull out the cigarette lighter and put it there.
1980 911SC Targa
1990 S2 Cabrio (sold)
2004 C4S (sold)
2006 Boxster (sold)
Old 03-16-2025, 01:27 PM
On my 75 it’s for wiper speed, but what’s wrong with your key for start stop?
Instagram: @TuitTech
Old 03-16-2025, 01:31 PM
SWS911's Avatar
I think it was for the rear "fog light" on the Euro cars.
Old 03-16-2025, 01:38 PM
The knock-out indentation is in the vinyl covering for the (euro) rear fog lamp switch, the diameter of the plastic locking ring, a smaller pre-drilled hole behind it to snug up the threaded switch shaft onto the metal dash frame. Good spot for a start switch or other gadget. Guess Porsche didn’t throw away old tooling for appearance sake.
Reference
Mystery Dash Switch 1980 911SC
Old 03-16-2025, 02:22 PM
proporsche's Avatar
it is actually not hole at all- unless you cut it out.. .It is a place where in 1987 porsche placed the auto-heat sensor
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-16-2025, 03:03 PM
I'm converting to EFI and the ECU is also a power distribution unit. I can use it to turn on the starter solenoid so I thought I'd add a start/stop button. It works perfectly. I just need to find a spot for it. No problem turning the engine over. Getting it to start, not there yet
1980 911SC Targa
2004 C4S (sold)
2006 Boxster (sold)
Old 03-16-2025, 05:35 PM
Thanks for the additional responses. I'll need to drill the metal panel to fit the switch. I was also considering replacing the cigarette lighter with the switch, but accessing it is going to be a pain. The old unused hole in the dash is accessible from inside the car.
Dave
1980 911SC Targa
2004 C4S (sold)
2006 Boxster (sold)
Old 03-16-2025, 05:39 PM
winter
Winter's Avatar
I have the same indent in my ‘76 dash, and posted about it here: https://forums.pelicanparts.com/porsche-911-technical-forum/1171639-dash-instrument-question.html
Plan was to install a switch for my power antenna there, but PO of my car deleted the rear wiper, so that switch may end up for the antenna power.
Tom
'76 Targa
Old 03-16-2025, 08:34 PM
