Question Hood strut replacement tricks
Does anyone have any hood strut replacement tricks.
The driver side lower retainer clip seems inaccessible to me!
Any suggestions would be greatly appreciated....
Old 08-26-2011, 07:49 AM
RETIRED
Joe Bob's Avatar
Hemostats....
Old 08-26-2011, 08:04 AM
na2ub's Avatar
A long time ago, in a land far away, someone else had that problem. After much fiddling, he decided to just leave the clip off, to find that the strut stayed in place just fine without, much to his pleasure. After that day, many have followed in his footsteps successfully, myself included.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
crustychief's Avatar
Hemostats....
Or a stick with some sticky tape.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 08-26-2011, 08:25 AM
very painful, as indicated above. don't think I got mine on either. Na2ub that is too funny.
72 911 T Targa 3.2
01 Boxster S
Old 08-26-2011, 08:28 AM
Spiderman
Jesse16's Avatar
I did my struts about 2 years ago and had forgotten this. Just checked and no clip, seems to stay in fine. Many thousands of miles and 4 DE's.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 08-26-2011, 08:33 AM
I just changed mine. I found the clip was missing from previous shock change. So that's how it stayed. Would seem very difficult to get clip back on.
Dean
Old 08-26-2011, 08:39 AM
schumicat's Avatar
it is pretty easy if you use bent nose pliers.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 08-26-2011, 08:44 AM
na2ub's Avatar
Could be a budweiser campaign commercial, if you remember those, "Mister leave clip off man, we salute you"
Doug
Old 08-26-2011, 08:48 AM
I was stubborn enough to use a long screwdriver and a piece of tape. But the clip is just a belt & suspenders thing.
Old 08-26-2011, 08:54 AM
PCA7GGR's Avatar
Use your kid's (or spouse's) narrower arm and smaller hand - ;>)
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 08-26-2011, 09:05 AM
fred cook's Avatar
Hood strut......
Once you've gotten the pin back in place, use a piece of small copper wire inserted and wrapped around the folded end of the clip. This will allow you to position the clip holding the wire and use a screwdriver in the other hand to press the clip into place. Then, unwrap the wire and remove. The wire that I use is about 18 gauge magnet wire (copper wire with a lacquer finish). It is a little stiffer than uncoated wire and will hold the desired shape better.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 08-26-2011, 09:26 AM
gtc gtc is offline
abides.
gtc's Avatar
Save on Sunex Tools 3706 at ToolTopia.com
Graham
1984 Carrera Targa
Old 08-26-2011, 10:58 AM
Recreational User
porschenut's Avatar
This really isn't difficult at all. Use needle nose pliers to pull the clip off. What I do is this:
1. Use a screwdriver or the pliers to turn the clip so that it would remove by lifting stright up.
2. Hold the needle nose pliers by the ends of the handles and lower the needle end in.
3. Grip the clip and pull it straight up and off.
4. Use the tip of the needle nose to push the pin through to the other side, and grab it with the pliers and pull out.
5. Replace the hood shock.
6. Installation is the reverse.
I can do the entire procedure in under 1 minute without uttering a sound. Not even a whimper.
Old 08-26-2011, 11:11 AM
Canucks Fan
Under 1 minute? I'd like to see that.
From the Deep Dark Jungle
Old 08-26-2011, 12:14 PM
ths911's Avatar
If you are going to put the clip back on, tie some dental floss to the clip before working in the tight area. When you drop the clip and you will, you can just retreive it by pulling on the dental floss.
1987 Carrera Coupe
Old 08-26-2011, 12:33 PM
burgermeister's Avatar
I'm with na2ub - no clip, 5 years, 18 or so DEs, no problems (with the hood strut at least).
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 08-26-2011, 02:44 PM
I did mine with long needle nose pliers. It wasn't that difficult.
Old 08-26-2011, 03:07 PM
SAM DACOSTA's Avatar
I just did mine on my 964 last weekend and it took a total of 5 minutes to do both 'hood shocks' and I had no issues with the clips. I'm wondering why others are having issues and what's the root cause (old clips, bent clips, etc.)?
SAM DACOSTA
1990 Porsche 911 Cabriolet (964)
2000 Porsche Boxster (986)
2002 Porsche 911 C4S (996)
Old 08-26-2011, 03:52 PM
Get a kid. Takes them seconds,
Mine charged $5.00
Old 08-26-2011, 03:59 PM
