-   -   O2 wire disconnected? (http://forums.pelicanparts.com/porsche-911-technical-forum/1175594-o2-wire-disconnected.html)
A930Rocket 03-24-2025 07:18 PM
Correct me if I’m wrong, but isn’t this the O2 wire, that is disconnected? I think there’s a reason people would disconnect them, but I don’t remember…
Well, it’s not letting me upload any pictures. 🤯
It’s a male and female round connector, with one black wire, and one white wire.
Does that sound familiar?
proporsche 03-25-2025 01:49 AM
i`m sure you will get some more re:
I took off the oxy sensor-plus CAT... the 1st day i got my 911-1985 back in 1996...I only used it for smog check -In CA...eventhou i passed the smog test once without it in LA land,back in 2007...
Otherwise i run my 911 without it....it controls the emission ..but most of the 911-Carrera will run very clean even with it disconnected.If you do not have catalyst there is also no need for it.
Ivan
A930Rocket 03-25-2025 06:35 AM
Thanks. The car is stock, with the catalytic converter and O2 sensor in place. It’s running good, so I will leave as is.
