O2 wire disconnected?
Correct me if I’m wrong, but isn’t this the O2 wire, that is disconnected? I think there’s a reason people would disconnect them, but I don’t remember…
Well, it’s not letting me upload any pictures. 🤯 It’s a male and female round connector, with one black wire, and one white wire. Does that sound familiar? Last edited by A930Rocket; 03-24-2025 at 07:42 PM.. |
i`m sure you will get some more re:
I took off the oxy sensor-plus CAT... the 1st day i got my 911-1985 back in 1996...I only used it for smog check -In CA...eventhou i passed the smog test once without it in LA land,back in 2007... Otherwise i run my 911 without it....it controls the emission ..but most of the 911-Carrera will run very clean even with it disconnected.If you do not have catalyst there is also no need for it. Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thanks. The car is stock, with the catalytic converter and O2 sensor in place. It’s running good, so I will leave as is.
