clutch pedal stiffness
Is there an (easy) way to adjust the stiffness of the
clutch pedal on a 911 88?
I looked through everything I could get my hands on and
only found something about adjusting the clutch pedal
course.
Ludovic
Old 07-04-2003, 09:29 PM
nostatic's Avatar
nope. Stifness pretty much depends on how worn the clutch is, unless there is something wrong with the system.
Old 07-04-2003, 09:45 PM
I think it depends on why it is stiff. If the throwout bearing is dry on the shaft then it is not easy. There is an adjustment on the clutch pedal assist spring that can adjusted to reduce pedal pressure. I don't think it does much though
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 07-05-2003, 05:42 AM
The first Carreras with the G50 transmission (87's and I believe some 88's) had a flaw in the release lever pivot shaft. The needle bearings eventually get dry and then the shaft tries to seize, resulting in very high pedal pressure to release the clutch.
There are two kits to fix the problem, a factory one and an aftermarket, but they both require dropping the engine/trans to install.
If you do a search for G50 and update you should get a lot more info.
Hope this helps.
Brian Boss
'71 914-6 2.2 MFI ............. '06 Lotus Elise
'71 911T (fake S) ............. '64 MGB
Old 07-05-2003, 06:22 AM
an 88 with a hydraulic clutch can't be all that stiff, can't it? Try an 84-85 instead and you will know what stiff is.
Anyway, not much adjustment is possible in any case. YOu can make sure that they work as new by replacing all defective components.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-05-2003, 06:56 AM
Also, replacing your clutch doesn't necessarily mean a lighter clutch pedal. It really depends on the pressure plate you choose. Pedal "smoothness" is a more important criteria. I recently installed a KEP pressure plate (Centerforce clutch) and the pedal is about 30% stiffer / firmer than the stock setup, but is smooth as glass. A great feel and clamps like a vice!
Good luck. My bet is that you need the fork update. If your clutch is the original, it may be a good time to do the entire system.
Mike
89 Carrera 3.6 V-ram #94
Livin' for Targa time!
Want to make God laugh?
Tell him your plans!
Old 07-05-2003, 07:49 AM
There are 3 adjusments at the clutch master end. They all should be within spec so the thing will work right. Mine is all lubed updated and adjusted and it is smooth as glass also
Dean
Old 07-05-2003, 03:13 PM
