Weight of stock SC
Can anyone tell me the actual weight of a 1979 SC Coupe with AC, sunroof and power windows?
About 2,800 lbs. As I recall......Do a search under Porsche 911 specifications...many sites out there...good luck!
Mike 83 SC |
Mine weighed 2955 lbs with me (185 lbs) during a cornerbalance
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
My stock euro '80 without me or gas weighs 2450 lbs. Measured on accurate corner scales. Lighter than I had expected. Does have power windows and sunroof, but no A/C. I think that weighs around 70 lbs.
-Rob 1980SC |
My '79 SC Euro without AC weighs 1120kg, I don't know what that is in American.
2464 lbs. For some reason I still remember its 2.2 lbs per kilo.
"I've only got half a key...I split it with the soundman." |
Team California
Should say in your owner's manual if you have it. I think that mine, ('82 U.S. coupe w/ sunroof, A/C), is 2750lbs. (1250kilos). It is in the specs& dimensions, look for *curb weight*.
Denis |
I do not trust the owner's manual. Every time I have seen road tests of other cars, the actual weight is always higher then the manufacturer weight.
I think the manufacturers list the minimum possible weight with no options. |
It'll be legen-waitforit
Wow, alot of differences...
79SC Targa with AC, no power @ 2550lbs. I'm hoping to get her down to at least 2400lbs
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
Administrator
I think what you're seeing here is the variation of results from so many 'calibrated' and 'certified' scales. In my experience, my car has never weighed anywhere close to the same amount on any two different scales.
And like speedometers, scales seem to tend toward optimism. As I've always understood it, the base weight of an SC was 2560 pounds, and that's without the additional weight of the optional-but-commonly-equipped sunroof, power windows or air conditioning.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Team California
It's funny, but when my car was corner balanced, it weighed almost exactly what it says in the owner's manual, which is 2756 lbs. w/ a full tank. (Refered to as 'curb weight' in manual).
I don't know how they can print one weight when obviously equipment makes a difference, but in those days, (1980s), pretty much 100% of U.S. cars came w/ sunroofs and A/C. For pretty accurate scales, find a place that rents construction equipment, they usually have digital drive-on scales.
Denis |
What does BBII weigh in at?
Keith 1979 930 2007 WRX wagon |
My 1980 was similar to Speeder's when I got mine corner balanced. 3/4 tank of full, spare tire, with jack and tool kit was 2,830.
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
"My stock euro '80 without me or gas weighs 2450 lbs. Measured on accurate corner scales. Lighter than I had expected. Does have power windows and sunroof, but no A/C. I think that weighs around 70 lbs."
-Rob 1980SC Another good reason to own a Euro, ESCWDP!!!!!
John Adams 1980 ROW 911SC |
Steve Wilwerding 1998 3.4L Zenith Blue Boxster 2009 Meteor Gray Cayenne |
Senior Member
Weighed mine two days ago on a WSDOT scale. A little disappointing. 2640. A/C removed. Includes sunroof and power everything.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
It depends on whether the scales belong to a longhood, SC or carrera owner
![]() I bet mine is pretty light these days, no AC, power, sunroof... engine. Last edited by thabaer; 07-03-2003 at 08:28 AM.. |
Team California
I cannot imagine what is missing on a 1980 euro car that would make it weigh 3-400 lbs. less than a similar U.S. model??
And A/C complete weighs something like 70 lbs., I think? And 20 gallons of gas weighs 140 lbs., so that would explain part of it.
Denis |
Also no extra metal in the body work for crash protection that was mandated for US models. I heard Porsche didn't start using it in RoW models until a company engineer was in a bad accident.
Not to corrupt the SC thread but. . . my '86 Carrera weighs exactly 2710 with 1/2 tank of fuel, jack and spare (less driver). AC removed, aftermarket front seats, aftermarket exhaust, sans rear seats, washer bottles, fog lamps, and all interior sound deadener.
Mike - PBG, FL '14 958 Cayenne GTS '05 997 C2 - SOLD '79 911 SC Widebody PCA, NASA, PBOC - SOLD 2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3 |
