1988 3.2 ignition coil resistance measures when wrong
Hi,
my brother's P is not starting anymore after 1y of standing still. There is fuel in fuel filter, engine turns over, ...
but no spark. Cables seem intact, distributor cap super clean.
When measuring the ignition coil resistance, I measured 1.2 Ohm primary on terminals 1 and 15 (where Bentley says 0.4 to 0.7)
and 2.8 kOhm secondary, where Bentley says 5 to 8
Is this still OK ? or does this indeed mean that as Bentley values are not met, the coil is bad ?
Old 03-29-2025, 02:47 AM
Originally Posted by gdp_samson View Post
Hi,
Found this, read here under Typical Ignition Coil Values;
https://www.systemsc.com/diagnostic.htm
And yes, the coil at 1.2 ohms will provide an adequate spark to start the engine.
Dave
Old 03-29-2025, 06:30 AM
If he has a silver Bosch coil on the car, it is very possible it is DOA right from the box, or in short order after installation. They are all junk. If you have the original 37 year old coil, it likely is fine unless it is oozing tar.
I have yet to find a good replacement coil with all the correct voltages, that really works. It is sad Porsche dealers will sell you a new coil made in Brazil that is just junk.
Old 03-29-2025, 07:13 AM
The MSD 8222 is a good choice.
Dave
Old 03-29-2025, 10:24 AM
The first place for a no spark I would check on a 3.2 is the speed and reference sensors. they are identical sensors so you should be able to compare resistance values between the two.
Old 03-30-2025, 05:36 AM
Hi,
we have measured the resistance on both sensors, and they seem to be OK.
Between 1-2 pin, 936 ad 946 ohms, and between 1-3 and 2-3 the digital multimeter was not able to measure the resistance, so I'm assuming that is 'more than 100,000 ohms' as Bentley's saying ?
so: 12.5 volts at ignition wire at the coil (ordered new coil jic but coil measured correctly, I think)
sensors giving correct resistance,
distributor cap and rotor super clean, spark plug cables clean (no breakage or bad rubber or...)
spark plugs are light brown and were replaced last year
but no spark plug...
will await the new coil (ordered the MSD 8222) and then check further.
Do I need to look at ECM (relay ?)
Old 04-06-2025, 11:39 AM
Hi,
Yes, this provides key 12V power to the ECM. Also, the ECM connector (35 pins - female connector) needs to have 12V on the three corner pins (1, 18, 35) with key-on.
Dave
Old 04-06-2025, 12:04 PM
The coil (really a transformer) is hard to test out of the car due to the voltages involved. I have a HiPot tester here and it only goes to 1200V. The coil is probably banging out 30X that. If the insulation isn’t happy you may just wind up subbing another coil to see.
The DCR readings (just checked on an OEM coil on an 88) are:
1 - 4: 5.89k. (this is the secondary)
1 - 15: .6 ohm (this is the primary)
reading 4 - 15 should look the same but is really 5.89k + .6 ohm. The ‘ground’ side of both coils runs to pin 1.
the coil should get +12V on terminal #15 when the ignition is on.
Old 04-06-2025, 02:22 PM
can I assume this is OK ?
Old 04-07-2025, 09:58 AM
have ordered the MSD8222 but I do have the correct voltages...
will provide feedback when arrived and installed
Old 04-07-2025, 09:59 AM
I did not understand this...
what is 'this' in 'this provides key 12V power to the ECM'...
must be my English (not native)
Old 04-07-2025, 10:01 AM
It's the DME relay, which provides 12V to the ECM, & fails often. Did you check the three ECM pins for 12V?
Buying another coil at this time without further diagnostics is a waste of money. If the coil is black & the original one, it rarely fails.
Dave
Old 04-07-2025, 10:14 AM
auch...no, I did not check that...the coil indeed seems original...
will try to learn from the Bentley manual on how to check these first...hmmm...
Old 04-07-2025, 11:22 AM
If the coil is getting 12V on terminal 15, the missing piece is probably getting the trigger from the DME unit. That could be wiring, dirty plug contacts, a DME fault..
The crank sensors are hall effect units, like a guitar pickup only the magnet isn’t in the coil, it on the flywheel. Not much to go bad but the wiring insulation flakes off over time. If the position sensor (bottom one in the bracket) is not sending a signal the DME usually won’t send a spark or fuel (since it does not know where the crank is!) this is a failsafe (generally, I don't know the specifics of this Bosch unit)
The manual states 960 ohms, +/- 96 ohms (10%) for those sensors. That is between pins 1 & 2 (counting from the bottom of the connector) 1-3 and 2-3 should be very high - they're just looking for bad insulation. My reference sensor value measured 1,055 ohms on my Fluke DMM, which is the top end of the acceptable range. The insulation tests were both off the scale which is great. (way into the MegOhm range) hope that helps a little
Old 04-08-2025, 08:39 AM
Actually, they are variable reluctance sensors.
TDC for two cylinders. After starting, it's no longer needed.
Dave
Old 04-08-2025, 04:09 PM
All posts helped tremendously...
it was a faulty DME relay
swapped one and car started immediately...
then suffered a lot with reinstall of the front seat that I did not bother to see what part of the old relay was (not) working
really happy with all the forum help I got, learned a lot
--> we did suffer with another issue (you wouldn't believe the story) but as it is another subject, I will start another post (after first going through the Search Forum option, of course)
thanks to all !
Old 04-09-2025, 10:57 AM
Oh, forgot to mention, as I made my brother buy a new ignition coil first, I did install that new one.
MSD 8222 as was suggested, is a direct swap, in the existing bracket. Install was a breeze and the car runs great (which might still be the case with the old ignition coil, I know...he will keep it as a reserve)
Old 04-09-2025, 10:59 AM
Yes, he should keep his black original coil as a spare, even if I find the secondary ohm test (2.8K) on the low side. When I checked mine it was 5.7k at the secondary. And 0.4 at primary.
Gilles
RoW 88 Carrera coupé
Old 04-09-2025, 11:20 AM
Yes, that's basically the value shown here (1st coil values - 911) under Typical Ignition Coil Values; https://www.systemsc.com/diagnostic.htm
Dave
Old 04-09-2025, 11:42 AM
will do !!
Old 04-09-2025, 11:54 AM
