Hose Rebuild Advice?
Hi Pelicans!
I am in the process of refurbishing and reassembling the CIS on my 1982 SC. These idle/vac hoses had at least one perished end. How have others rebuilt or addressed these hoses? Having trouble finding a hydraulic shop locally that is able to help.
Thanks,
Mike
Mike
82 911SC Targa
Old 03-22-2025, 12:43 PM
You might check with forum member BoxsterGT. He makes 3.2 fuel lines, but not sure he makes what you're seeking. Check out his recent post:
https://forums.pelicanparts.com/porsche-911-technical-forum/1089084-3-2-motor-fuel-line-re-make.html
Good luck.
Roger
1984 911 Carrera coupe
1972 911T coupe (owned 1978-1995, sold after divorce. . . . bummer)
Old 03-22-2025, 01:11 PM
Good luck.
Thanks Roger! Len rebuilt my fuel lines. I may reach out to him if there isn't a DIY method.
Mike
82 911SC Targa
Old 03-22-2025, 02:32 PM
See if you have a Tube N Hoses franchisee close by. You can search from their website https://www.tubesnhoses.com/system-locations. The one 30 minutes from my house was able to crimp on new sections of appropriate hose.
1990 928 S4
1998 Boxster
1978 911SC coupe
Old 03-22-2025, 03:48 PM
Still here
pmax's Avatar
That AL "claw" is also prone to cracking at the joints, not one of Stuttgart's most esthetic or well thought out contraptions. You would think there's a simpler cheaper setup to split a vacuum.
Not only that, let's hide all this behind the engine so they can't be serviced easily. Maybe, the engineers responsible could explain this some day for posterity's sake.
Old 03-22-2025, 06:18 PM
Check out this thread on the use of NORMA hose clamps.
CIS hard air lines rebuild
Old 03-23-2025, 04:09 PM
Hi,
Oetiker type stainless steel clamps are another option for this application.
Old 03-23-2025, 05:05 PM
Originally Posted by Magyar Kiwi View Post
Hi,
I can use clamps for the larger, 3 point line, but the smaller elbow shaped line does not have barbs/flares on it, so I'm a little hesitant on clamps. I will try to find another shop that will work on it. I have been turned down a couple places already.
Mike
82 911SC Targa
Old 03-24-2025, 08:46 AM
I believe the hose and finials are available from bellmetric. Rob
Old 03-24-2025, 01:55 PM
Thanks all.
I have tried one of the Tubes and Hoses stores and the other local one is shut. Will look at other shops in the area.
Rob, I got to bellmetric. Looks like the crimper is $2k but they do indeed have the fittings!
The oetiker clamps are a good idea for the larger tube. Considering that since there are flares in it.
It is the smaller hose without flares that I am more concerned about. I want to ensure a lasting seal, then again, it is a sort of encapsulated fit, with it being bolted down and all... perhaps oetiker would be fine there too.
Mike
82 911SC Targa
Old 03-29-2025, 10:49 AM
BoxsterGT's Avatar
Porsche Crest
Oetiker clamps are fine for everything except the high pressures of 60 psi or more.
Len
Old 03-29-2025, 10:55 AM
I don't see where you are located, but Hoseman, in Oxnard, California was convenient for me. I could walk up to the counter with my old hoses and they could make whatever I wanted. Type of hose, type pf fitting, length. They specialize in Cat, Deere and other heavy duty equipment hoses.
Old 03-30-2025, 05:03 PM
Thanks all. Have some oetiker clamps on the way. Will get some hose and refurbish these. Will post results.
Mike
82 911SC Targa
Old 04-05-2025, 11:28 PM
Tags
cis , vacuum hoses
