915 transmission rebuild "while I'm in there"
I've done a search, but I can't find the list of things to do while I'm having my 915 transmission rebuilt. Can someone point me to the thread or give me a list of things to do while the transmission is apart and out of the car?
Thanks,
Sean
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 06-16-2006, 11:01 AM
Bird. It's the word...
Fishcop's Avatar
Check out the Wevo site, there's a couple of cool additions. I'll definitely be installing the internal gate upgrade to help shift accuracy and to help prevent bad shifts at the track.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 06-16-2006, 05:39 PM
Mookster's Avatar
The engine and tranny are out as one unit.
If you are doing it yourself:
1. replace engine vacuum lines
2. replace fuel injector O rings
3. replace/check engine fuel lines
4. replace oil thermostat O-ring
5. replace engine breather gasket
6. if you remove CIS assy replace intake gaskets
7. replace clutch assy
8. replace flywheel seal
9. replace flywheel bearing
10. valve adjustment
11. replace clutch fork
12. replace all synchros, 1, 2, and 3 gear, check 4 & 5 and replace if needed.
13. all shifter bushings (shift rod, tunnel, and coupler)
14. Throttle linkage bushing replacement
15. replace engine sound pad
16. Replace/balance flywheel
If a shop is going the work and you have a budget:
#4,5,7,8,9,11,12,13,16
Take advantage of overlapping labor. Don't be penny wise and dollar stupid.
I'm sure I missed something. Others will chime in, I'm sure.
If it has a skirt or tires, it WILL cost you money!
Old 06-16-2006, 06:03 PM
Crotchety Old Bastard
RarlyL8's Avatar
You might add a WEVO bearing support for insurance.
Old 06-16-2006, 06:50 PM
Elombard's Avatar
Also might as well throw in a LSD...its only money:O Any body else see where BA in the last excellence highly recomends a LSD if you are doing any autoX or track stuff.....depressing I thought it was a luxory now I feel like I have to have one.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 06-16-2006, 08:26 PM
Air Medal or two
afterburn 549's Avatar
http://www.pelicanparts.com/MotorCity/marcesq3/TrannyRebuild.htm
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 06-16-2006, 08:48 PM
