Fuel filler sleeve
Hallo,
how to install a new fuel filler sleeve with the fender mounted? Kris |
I seem to remember that you have to pull the filler neck out of the pocket a little
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
I would rather be driving
remove the two hoseclamps from the sleeve. slide the sleeve towards the tank. pull the filler neck out of the fender slightly. remove and replace sleeve. The filler neck may be tight if the seals are old. You may want to replace these as well as the gaitor between the fuel filler pocket in the fender and the inner fender well.
best of luck
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Trying to do this myself...so concensus is I have to remove the filler neck? It does seen unlikely I can get the new sleeve in place even if I cut the old one out, which is hard as a rock. Hopefully removing the filler neck is pretty obvious.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
