Warm idle Lambda AFR
Engine is warm after 20 minute drive.
First pic. O2 sensor unplugged, FV defaults to 50% as it should, AFR set to about 13.6 as seen here:
Second pic. O2 sensor plugged in. FV previously set by me at 40-45, AFR drives leaner to about 15.8 as seen here:
Is this normal lambda controlled AFR behavior for warm idle?
Secondly, if FV number decreases from 50 to 40, shouldn’t that richen the AFR?
Old 04-17-2025, 03:56 PM
Anyone else with stock lambda and CIS have 15.7 AFR at idle?
Old 04-18-2025, 06:12 AM
AndrewCologne's Avatar
Where is that AFR gauge connected to, the narrowband 0-1v signal?
I guess not as with a narrowband signal it can't read steady AFR 16:1.
So are you using a wideband controller? and if yes, ... what resulting voltage of the controller equals Lambda 1 / AFR 14.7:1
1. If you're using the stock eco, ... use the orig narrowband sensor and read the voltage of the green wire on port 2 of the ECU, ... does it swing between 0.1-0.9v?
If yes then you're spot on Lambda 1
2. Is your exhaust system stock as it left the factory? Cause removed Cat or SSIs do affect the resulting sensor signal.
3. I would not focus on AFR, but on lambda as that is the native reading of the sensor. AFR is just "calculated" from the sensors lambda reading and also depends on the ethanol content. Be aware that with 5% ethanol at lambda 1 the AFR equals to 14.4:1.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 04-18-2025, 07:33 AM
Dr J's Avatar
I have an SC converted to EFI so I have played a lot with AFR in all conditions. I can tell you that these cars will not be happy idling that lean (15.7). I have mine set at 14 and it idles well at 13.6ish.
While Andrew is correct that a stoichiometric mixture of gas with 10% ethanol has a different actual AFR value, that will be irrelevant since you can just read the AFR as if you had 100% gas with 14.7 being stoich.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 04-18-2025, 10:35 AM
Seems his car ist still running the original lambda based k-jetronic and with these models idling at Lambda 1 / AFR 14.7:1 is still ok and smooth. The only drawback with the original ECU is, that idling oscillates a bit within around 50 rpm. As with these old ECUs the 0.5 to 1 kHz swinging narrowband signal will be 1:1 forwarded to the ECUs duty cycle generation.
Old 04-18-2025, 11:05 AM
Original lambda system intact, new O2 sensor, new O2 relay. At cruise throttle AFR waivers around 14.3 goes to about 13.5 at WOT.
I do have SSI exhaust but surely it would not make that much difference at idle. JBell custom AFR gauge that I sent back to him to verify it is calibrated correctly
14.3 at cruise and 13.5 at WOT seems in the ball park but 15.8 at idle seems out of whack with lambda hooked up. I can super richen it by turning the mixture screw to force the system to 14.4 at idle, but then it will be so rich it surges badly and won’t start (too rich).
Old 04-18-2025, 03:03 PM
Still not answered the question:
What provides the voltage to that individual made AFR gauge?
Is it the original narrowband signal (where here I think it's not) or a voltage signal from a wideband controller? If yes, then in the gauge at what voltage is AFR 14.7:1 (Lambda 1) present ??
I ask cause ... maybe the gauge expects a different voltage which equals Lambda 1 / AFR 14.7:1.
So ... 2.35, 2.45, 2.5 or even higher volts.
No you can't, you did not understand what the lambda control of the ECU does --> no matter if you turn the CO screw for enrichment, at the end with closed loop control the ECU forces the Mixture to result in Lambda 1. So if you enrichen the mixture with the CO screw the ECU simply will decrease the duty cycle to make it result in Lambda 1 again.
Surely? :-)
It does make a difference. Cause the sensor in an SSI system at idle will result significantly colder than with its position in the original exhaust system, means much nearer to the exhaust port of the head and especially in front of the CAT which will make the sensor resulting much hotter at idle and therefore running more precise. And I guess you deactivated the ignition retard function at idle by disconnecting the second hose at the back side of the dizzy can? If yes, then your sensor will result even colder, cause the original retarded ignition timing with 5° ATDC at idle will let the exhaust flow result hotter at idle compared to the regular ignition timing using 5° BTDC.
Yes thats common, ... the original ECU only rises the duty cycle to static 65% at WOT, which does not result in the needed AFR 12.5:1 (lambda 0.85) for optimal combustion power, but in 13.5:1. Thats due to keep over all emissions within the limits in these years.
Old 04-18-2025, 04:43 PM
It’s an AEM wideband controller. Used by many others here over many years in conjunction with SSI exhaust. What’s a bit different about mine is the JBell gauge, but he has made dozens of them for many here that use the same controller.
Are you saying 15.8 could be normal idle reading with SSI’s?
Out of town for the weekend. When I get back I will take a cold start video to get your impressions.
If my FV is set to 45% with O2 connected, should my AFR gauge read 14.7 at idle?
Old 04-18-2025, 08:18 PM
Do all These users drive that controller in combination with that gauge in a lambda controlled k-jet car? As said, its all about the voltage wich equals Lambda 1, if the controller delivers a voltage where the gauge expects a different one for AFR 14,7:1 then ... the reading won't be correct, ... but I just assume, ... as ...the orig ECU with original exhaust system should let result a reading of lambda 1 at idle and normal driving. If not, then oxygen fluctuations in the exhaust flow could make readings get messed up, or the position of the sensor does affect its resulting voltage.
No, ... in my case with SSIs at idle the duty cycle rises more to match lambda 1, means the sensor reads to lean. In your case it's the opposite, ... the final lambda 1 reading is a bit too lean.
So, ... check the sensor, but it's a new one, as you said, and here ... is that new one even faulty as well? IN times of today sometimes with new spare parts you get even more into more trouble.
Or, ... the ECU could be faulty, targeting a wrong value.
Old 04-19-2025, 12:17 PM
Hard to figure out. Been through at least 4 O2 sensors, 3 O2 relays and I have a spare O2 ECU that reads exactly the same. Even changed the O2 sensor-to-ecu connector.
The AFR makes sense in open loop ie, WOT or before O2 kicks in. In closed loop too lean.
Another example. Using Gunson Gas Tester I set the CO to 1.5 on Wednesday. This should be a bit rich for my car. Plugged in the O2 sensor AFR went straight to 15.8
The ecu does not know what exhaust I have or where the O2 is plugged in or whether I have unplugged the ignition distributor retard hose. All it knows is once it receives O2 sensor input is to vary the FV to achieve 14.7 AFR. Mine is either doing that and the indicator is wrong, or the gauge is right and the ecu is seeking the wrong value.
I did send the gauge back to John Bell and he double checked the gauge was calibrated properly for my AEM controller.
I had a hard time getting the gauge wired up. It is a split voltmeter/AFR gauge (see pics above). It’s been a couple of years so I will go back and check my grounds and verify what wire goes where. But as I said, in open loop it looks to be working properly.
Lastly, I recently bought a used Lambda ECU wiring harness from another Pelican. It’s possible I could have a short or broken wire somewhere but I am grasping at straws there. It’s literally the only thing I have not changed.
Thanks for everyones input. Always appreciated.
Old 04-19-2025, 04:21 PM
With hot engine and lambda system operating in closed loop state, ... now at idle turn the CO screw in a way so the duty cycle swings around 50 and 55 %.
With that setting what AFR is shown on your AFR gauge at a) idle? and what AFR at b) WOT / High load
Thought too simply ... The ECU itself surely not, but the oxygen amount in that area of the exhaust system where the sensor is installed to can be affected by several things, as described. Like air leaks in the exhaust system etc.. And that "will" affect the sensors reading, .. as well as a non proper operating temperature of the sensor, even with a heated wideband model. Cause heater of heated sensors do help for faster self initializing, but the target operating temp will be achieved and kept by the exhaust flow temperature.
Old 04-20-2025, 08:00 AM
Is this possible? I set AFR to 14.7 at warm idle and FV reads 11%?
Thought I read the FV range is 20% to 70%.
Old 04-22-2025, 08:37 PM
The range of the original ECU is from 5 to 95%.
At open loop the initial set up of the CO screw with the original ECU should result 0.4-0.8% CO, then (normally) when changing back to closed loop the Duty Cycle rises a bit till it swings around 55%.
Your workflow above shows clearly that the sensor reads a value which does let the ECU think its too rich for lambda 1 (AFR 14.7:1) and so it pulls the duty cycle down.
How is your setup in detail?
- Does the AEM Wideband controller –beside the signal for the gauge– provide also a simulated narrowband signal (Like Innovate controller do) which you use as signal for the ECU?
- Or do you use two sensors, one original sensor with signal for the ecu and another wideband with signal for the AEM controller?
Old 04-23-2025, 03:49 AM
This is how it is set up.
So I can set mixture in closed loop with AFR or FV but they do not agree.
Old 04-23-2025, 07:46 AM
Well, ... then one of the units (ECU vs AEM) does interprete the sensor differently or one of the sensors give different signals at lambda 1.
Or ... if the sensors are installed one on the left side and the other on the right side, then maybe the mixtures/combustions are different on each side, ... but then the reading of the plugs would show it clearly
So ... without going more and more into theoretics ....go to an official emissions check point or service garage with testing equipment and let an official calibrated device do the test. There you can see which one is on spot, .. the ECU or your AEM Controller.
BR
Old 04-23-2025, 09:22 AM
PCA Member since 1988
Do you have both the OXS ECU and the gauge hooked up to the same O2 sensor, or separate sensors? If separate, you may be getting different readings on one bank of cylinders versus the other bank, due to uneven fuel distribution, or intake leaks, or exhaust gasket leaks.
I would also put a digital voltmeter on the output of the O2 sensor to see whether your gauge is calibrated. At Lambda=1, it should be about .45 volts.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-23-2025, 12:09 PM
BR
When the O2 sensor is unplugged, the FV goes to 50% as it should. I also have a spare
ECU which has exactly the same readings. Both of these lead me to think the ECU is OK
What do you think of these other readings? All normal? Should Vmax be 6.48V be higher?
Old 04-23-2025, 02:35 PM
They are on separate banks. I have recently warmed up the car, unplugged O2 sensor so that FV goes to 50% and noted the O2 reading. Then shut off the car and removed the OE O2 sensor and put the AEM sensor in the OE cavity and restarted the car. Difference was only .4 AFR right side was higher. Meaning that I can look at the AFR gauge and subtract .4 to get what the OE sensor is outputting.
The difference here is much greater than that. I can set mixture in closed loop with FV or AFR gauge. If I use the FV to set mixture at between 45%-55% the AFR at warm idle reads 16.8% (see pic above) If I set AFR on the gauge to 14.7% (then subtract .4 to get 14.3% actual) FV reads 11.6%.
“I would also put a digital voltmeter on the output of the O2 sensor to see whether your gauge is calibrated. At Lambda=1, it should be about .45 volts.”
What is the best way to do this? Back pin the O2 connector (?) or is there a better place to check it with the car running?
Old 04-23-2025, 02:55 PM
I already know that both of your original ECUs do give same readings.
But as already mentioned above -> your original ECU(s) and the AEM unit both do read the signal of their sensors differently.
The ECU results in Lambda 1, and the AEM controller system says it's a way off.
To check if the ECU really results in lambda 1, follow PeteKz's advice and with your oscilloscope read pin 2 at the ECU if the voltage signal swings between 0.1 to 0.8 volts – if that is the case, then your ECU behaves as it should and you're on spot with Lambda 1.
Then you should ask yourself why "on the other side" of the engine, the reading is different than Lambda 1, and here the options are a) AEM readings are off, or b) the mixture is different than on the other side of the engine.
As its the test port output, for me its ok
Old 04-24-2025, 12:43 AM
https://youtube.com/shorts/AP-rX-AY0SE?si=NcbrvHMg7vEfM43e
Looks ok
Old 04-24-2025, 05:46 PM
