78 911sc targa top won't come off, missing handles
Hi all, I'm new to my project car, a `78 911 sc Targa. The targa top needs repair and I'm trying to get the top off to send to Targa Dan in NJ. However I'm sort of stuck trying to get the top off the car. There are no handles to turn the barrel nuts. I was able to turn both nuts to the left, counter clockwise 90 degrees where it seems to stop. The top does release about 1/4 inch, but is still latched. Am I missing something? Do I need to have someone pull up on the top while I try to turn the barrel bolt another tiny amount? Is there another way to get the top off If I'm totally stuck here? Any advice and tips are welcome. Much appreciated.
Old 04-18-2025, 01:46 PM
Welcome and you’re on the right track, the latch has a spring loaded sort of safety mechanism, so you’ll need to turn them slightly more against the tension to release them. It will be easier to turn them both at the same time while pushing up on the top.
Rutager West
Old 04-18-2025, 02:39 PM
Targa_PB_78_SC
mike sampsel's Avatar
If you get the bolt to where the top will come up some, I think you need to turn the bolt another 10-20 degrees to get the "safety catch" to release and while you are doing this get someone to pull up and then don't let it drop down again as it might catch. Seem to be tricky with just two people might need three to turn both bolts simultaneously and lift too.
Just tried mine, and it's about 90 degrees on the latches then the top will move up, and then another 10-20 degrees to get it off its claws.
BareRearedRookie
Old 04-18-2025, 02:50 PM
Thank you both! I may need 3 people because one of the barrel bolts is broken and I have to use needle nose pliers on it. The other one I can use a big screwdriver on, but I can't do them both at same time! I don't think this top has been off in 17 years! 2008 is last registration date.
Old 04-18-2025, 02:53 PM
Targa_PB_78_SC
Here is what the part looks like on Pelican parts: Use this part number
91156503141
BareRearedRookie
Old 04-18-2025, 02:58 PM
Targa_PB_78_SC
Here is the part number for a handle,
911-565-075-41-M1249
which might help some. You are going to find rebuilding your top is not gonna be cheap.
BareRearedRookie
Old 04-18-2025, 03:06 PM
Targa_PB_78_SC
FYI, there is a targa top for sale for $2000 on the used parts link.
Just letting you know.
https://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1176564-porsche-911-targa-top.html
Cheers
Looks like it's missing a handle?
BareRearedRookie
Old 04-18-2025, 03:13 PM
Since you are sending it to Dan, he should be able to set you up with a new or repaired latch and handles.
Quick note, the handles come in different lengths, so if you don’t get them from Dan, check needed length.
Rutager West
Old 04-18-2025, 03:21 PM
Tags
latch , missing handles , stuck top , targa tops
