Regenerated User
72doug2,2S's Avatar
Replace or reuse, 38mm stainless early rear caliper piston
Replace?
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law.
'72 911T 2,2S motor
'76 BMW 2002
Old 04-28-2025, 02:24 PM
that looks like a chrome plated piston to me, not stainless.
Old 04-28-2025, 02:34 PM
Regenerated User
72doug2,2S's Avatar
Perhaps, although I don't see an option for that on our host site
'72 911T 2,2S motor
'76 BMW 2002
Old 04-28-2025, 05:12 PM
You have it apart so just put a new one in.
Old 04-28-2025, 05:53 PM
Hi
The original OEM pistons are chrome plated steel and prone to rusting..
The replacement non OEM ones these days are often made from stainless steel, removing the rusting problem.
If you choose to replace, probably best to replace both pistons in the caliper.
Cheers
Old 04-28-2025, 09:10 PM
Regenerated User
72doug2,2S's Avatar
These little guys were such a pain to remove. The air compressor barely moved one side.
I bought a cheap $77 Chinese Vervor diesel pressure tester and mated up a 12mm connection (to a rubber hose i found on a Mercedes repair site) to the caliper. I fixed the diesel leaks by applying a few wraps of plummer's tape to the inside nipples (cleaning the holes for flow) after connections I ran a small wire to clear any incidental Plummer tape blockages. No leaks!
'72 911T 2,2S motor
'76 BMW 2002
Old 04-29-2025, 04:24 AM
Regenerated User
72doug2,2S's Avatar
Originally Posted by Magyar Kiwi View Post
Hi
Cheers
Since the pitting is at the very end would that come in contact with the square round rubber ring?
'72 911T 2,2S motor
'76 BMW 2002
Old 04-29-2025, 04:44 AM
I would use it. The corrosion on the end might only come in contact with the seal when the pads and rotors are brand new even then likely not or just barely.
Old 04-29-2025, 05:31 AM
Counterclockwise?
That is before the seal. Just shine it up to remove the rust.
Rod
1986 Carrera
2001 996TT
Old 04-29-2025, 11:13 AM
I've just done mine and they were similar. Clean it well and grey scotchbrite the pistons. It'll be fine.
Old 04-29-2025, 02:28 PM
Regenerated User
72doug2,2S's Avatar
As long as they don't come in contact with the rubber I think I'll reuse these.
Thanks all
'72 911T 2,2S motor
'76 BMW 2002
Old 04-29-2025, 04:46 PM
