Car is
My 2$
Check that the plugs are seated...if you have the rubber seals
around the extensions, and the plugs are screwed in, you should not be feeling air being pumped out. This would also account for rough running. Also, make sure the plug wires are on the proper plugs...the mechanic could have crossed a couple. Good Luck!
Impotence...Nature's way of saying "No hard feelings." McDaniel 1974 911 Targa 1995 Toyota Avalon 2004 Toyota Tundra Extended Cab |
Sounds to me like the plugs wires are crossed and a lot of raw fuel is burning in the cat. Sort the wires one by one.
NO they are not crossed. LOL! Everyone is suggesting this one as a possible solution...but its 100% sure that they are all properly connected. Thanks though.
Super Moderator
If you're feeling air coming out of the cylinders on firing your plugs are not seated.
If your cat converter is glowing read, sounds like it's plugged up. check your exhaust and see if you are getting good flow. I have seen cat converters glow read for this reason. I would definitely check it out - potential for fire.
Steve "A Porsche does more then just go fast in a straight line"
SteveKJR Proud Owner of a 78 911 SC Targa "A Porsche does more then just go fast in a straight line" |
Administrator
Plugged-up cat.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
of course it is plugged...
where are you located in So Cal
1. Find out why the two plugs aren't seated and install them correctly ... assuming you haven't crooss-threaded the heads!!!
2. If you still have mis-firing after the above is done ... take the car to a shop with an ignition analyzer scopem, or borrow/rent one, and find out if there is an ignition system problem ... the distributor only has one possible setting on a Motronic engine, so ANY timing problem is an ECU problem, not a mechanical adjustment problem. 3. Quit 'guessing' about the cause, and try to use some logic and gather data as requested here ... troubleshooting & repair by 'shotgunning' this problem could get very expensive!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
6 years ago the first time i had my car painted, somehow they knocked the wire off for the oxygen sensor, i got about 4 miles car shuts down same problem, by the way I think your o2 sensor is right by the cat, Kevin
Thanks Warren. .
The Unsettler
Did you have the valve job redone by a mechanic?
1st time I did my valves I had exactly the same rough running/missing/no power problem. I thought it was wires also especially since I saw some arcing on one. I did the adjustment again and rechecked each one afterwards and a couple were tight. If I remember correctly you only did #1? Are you sure you used the correct mark for Z1? Om my car it is the 1st of the 2 notches on the pulley and the rotors leading edge, not the middle of the contact, should be pointing at the notch on the dizzy. Good luck. Scott
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
stomachmonkey...
Senior Member
Yes, .1mm is small, but poor valve clearance will not cause the symptoms you are reporting. Frequent firing failure could. that is, if your spark plugs are not firing but half the time, then raw fuel will go into the CAT and it would glow and run REALLY poorly. Perhaps borrow a set of known good plug wires. I'd agree with Warren that you can easly spend a LOT of money trying to fix this by purchasing and trying (shotgunning) parts.
My guess is ignition trouble. My strong guess.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Have you measured the 02 sensor output? Running rich or lean? As others have said, cat can cook if mixture isn't right. If plug isn't firing at all, that may actually lower cat temp because of excessive fuel not actually burning, but dissipating heat. Excessive retard will usually heat it up very quickly.
John 86 Coupe - Sold Macan GTS Ducati Multistrada |
It sound like very lean condition. This cause severe high temperature in the exhaust system. Check the air/fuel ratio to see is correct.
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
