-   -   SC starter removal - help me see what I can’t see (http://forums.pelicanparts.com/porsche-911-technical-forum/1177313-sc-starter-removal-help-me-see-what-i-can-t-see.html)
Otter74 05-05-2025 08:45 PM
I don’t recall oart number but I believe it’s the first of those two.
Originally Posted by REVerend (Post 12459534)
This is making me want to preemptively replace my starter on my 83 SC when I drop the engine.
Get the high torque starter part PEL-GE-STHT that’s at the top of the list at Pelican or the WOSPerformance WSP-LMS1102 ?
Or some other choice? Which one did you get OP?
Robcat77 06-28-2025 01:30 PM
I need to replace the 10mm barrel nuts for the starter. PO had them pretty well stripped and were a bear to get off.
Pelican sells the cylinder head barrel nut, but not sure if that's exactly what's used for the starter.
Has anyone had to purchase these?
Here's what I found on Pelican:
https://www.pelicanparts.com/More_Info/UR90110438202.htm?pn=UR-901-104-382-02&bc=c&SVSVSI=0581
