LinkBack | Thread Tools | Rate Thread |
Kind of Blue
Rennshift Problem - Gear Throws Became Super Long Then Couldn't Engage At All
I was out for a spin and all of a sudden I go into first but the throw of the shifter just keeps moving despite feeling it go into gear. Somehow, I'm able to still use 2nd, 3rd, 4th (fortunately only a mile or so from home).
I finally come to a stop and cannot find first or second, just third, which I punch to pull out right onto the road in front of my house. As I pull up to the garage, it won't engage any gear and the shifter seems "stuck." I shut it down and play with the shifter a bit and somehow get it in gear but can't get it out despite the shifter still moving slightly in the assembly. Did I lose a coupling somewhere? I had to have my son hold the clutch down while I pushed the car into the garage. I'm assuming this is a simple fix somewhere. The transmission has maybe 1000 miles on it since a rebuild, but something tells me this is a shifter assembly or coupling issue somewhere.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
The first place I would look is the shift coupler that attaches the shift rod to the transmission .
Kind of Blue
I should have added I was out on a "test run" after I noticed the shifts getting noticeably gummier just this last week to determine if that was just in my head or actually real.
Happened to me recently. The clamp that holds the shifter coupling had gotten loose and dislodged the coupling from the shaft. Had to reinstall and adjust the coupling where all the gears would engage properly which took a lot of fiddling around
Kind of Blue
Sigh, this is exactly what happened to me. This should be fun!
Kind of Blue
Kind of Blue
Reconnected and adjusted. I seem to have all 5 gears and reverse. It's raining so I'll give it a run later this week. Took all of five minutes.
For future emergencies, I'm going to make sure I have a 13mm wrench in my tool roll.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor Last edited by MrBonus; 05-04-2025 at 09:53 AM.. |
That will do it.
My recommendation once you have the coupler adjustment where you like it : Make 2 paint marks, one rotationally and one longitudinally, at the coupler. This allows you to glance at it to see if it has slipped and also remove and reinstall/ adjust the coupler very quickly and easily. |
Did I leave anything out?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Been here a while
I’d add a 4mm Allen wrench and to the OP, I’d make sure the 4mm set screw is nice and tight.
looking for 1972 911t motor XR584, S/N 6121622 |
Man, isn't it nice when you think something catastrophic happened but it's just an easy fix?
"Purists are the Karens of motorsports. IG - Iron_Dad_Moto 1972 Porsche 911 - Long Term Project. 3.6TT/G96.50 1981 Porsche 911SC - In Progress. F/A-18C/D, F-15C, F-35B/C |
It’s amazing how often that little joint, becomes loose or disconnects.
Kind of Blue
The funny thing is in the past week I noticed reverse and first had a few light grinds during engagement which it hadn't done previously. I suspect this had been working its way loose so I'm curious to see if this stops once I get everything adjusted to my liking. Thanks, everyone!
Get James' Rennshift Coupler Clamp. Much easier !
https://www.jwestengineering.com/911-Shift-Coupler-Clamp_p_24.html
Robert Callaway PCA | Early S Registry | R Gruppe 1970 T Coupe, 1990 C2 Coupe, 2007 Cayman S 1962 S90 Coupe - Gone, but never forgotten... 1985 Targa - A distant memory... |
Kind of Blue
You guys are quick! Easiest fix possible!
Kind of Blue
The silver lining of this problem was taking the time to watch your 25 minute YouTube video to better understand the function of adjusting the coupler bushing as well as how tight the shifter fork assembly is, which helped me understand that since it was likely "slipping," it was causing 1st and R to intermittently grind in the past week.
Now once it stops raining, I'm going to take the time to properly adjust it all from scratch.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor Last edited by MrBonus; 05-06-2025 at 06:34 AM.. |
