TyFenn's Avatar
Are these really the same part?
I've heard that these are indeed the same part. As you can tell, the top of each part is different. So, does that mean I need to splice the orignal line, since the connectors are different (one round and one flat)? The part in the bag is # 930 606 117 00, the other part is number???
Thanks,
Happy 4th.
We can share the women, we can share the wine - Jack Straw.
1970 911t w/3.0
1971 914 w/2.0
1987 300E
Old 07-04-2003, 03:23 PM
TyFenn's Avatar
maybe this is a better pic?
1970 911t w/3.0
1971 914 w/2.0
1987 300E
Old 07-04-2003, 06:03 PM
You do not have permissi
john70t's Avatar
Try using an Ohm meter to check the resistance at different temperature(pot of water off the bottom) against book specs with a thermometer in the water. Sometimes they change the connectors/color for no other reason other than to sell the same thermoresister for multiple cars.
Old 07-04-2003, 09:47 PM
TyFenn's Avatar
Is it recommended to splice this wire to get the newer flat fitting to work? I guess I could hammer it out a bit to flatten it and then try to connect it?
Look here - circular connector (and bad spelling)
It's a little blurry but...
1970 911t w/3.0
1971 914 w/2.0
1987 300E
Old 07-06-2003, 01:48 PM
