5th Gear for Highway Cruise and "GAS" Mileage
My 1979 SC sits near 2800rpm (according to the tacho) at 100kmh or 60mmph. Our speed limits are generally 100kmh on open highway. Some are up to 110kmh.
I'd like to be doing considerably lower rpm when cruising. I drove a friends car and his seems to be maybe 2600-2700 at the same highway speeds but I dont know what diff is in his box or the ratios. Looking at the ratios that came with these (according to the CMS website) I am guessing my car has a 28:23 (0.82) and my friend has a 29:21 (0.72). Looking at the Albins site, they offer 0.79 - 29:23 0.76 - 29:22 0.72 - 29:21 0.68 - 31:21 0.59 - 32:19 That's quite an expansive range.. has anyone used any of those ratios? Using motoristo.com and plugging in my diff ratio, (8;31) tyre size etc, 275/40/17 and with my ratio of 0.82 I'm at 2750rpm for 100 kmh. Here's the numbers for the other ratios.. 100km/h - and resultant rpm 0.82 2750 0.79 2600 0.76 2500 0.72 2350 0.68 2250 Engine is a 3.0SC converted to turbo and efi.. do we think 2250 is too low rpm to be cruising?
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP Last edited by mikedsilva; 05-20-2025 at 03:57 AM.. |
Full Send Society
I (Tony) put a taller 5th (TM = 29:22 = .759)
in my 915 and it’s been really great on the highway in the fast flat Midwest. At 80pmh I’m at about 3200 RPM which is a big change from the stock gear which had me at 4500 RPM for 80MPH I’ve never driven on the highway at 60 in the Midwest ![]() Sent from my iPhone using Tapatalk
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
'81 911 SC '03 BMW M3 (Sold) '64 VW Beetle, 2332, 48 IDA (Sold) Instagram: @j_smallwood |
Full Send Society
FWIW, I got my 5th from EBS, it was like $800, I tried to find cheaper but it was a waste of time... it is what it is...
Second data point: at 80mph I can get anywhere from 22-28mpg, more if there's no wind or I'm drafting a larger (any) car... For frame of reference, my 2021 Audi Allroad gets about 30mpg at that speed. My old Nissan Murano got maybe 20 on a good day...
does your friend has the same size of tires?
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
"Purists are the Karens of motorsports. IG - Iron_Dad_Moto 1972 Porsche 911 - Long Term Project. 3.6TT/G96.50 1981 Porsche 911SC - In Progress. F/A-18C/D, F-15C, F-35B/C |
29:22 was perfect for my setup. Some folks go taller with 29:21, but I feel that might be too tall.
Here is a earlier thread about my 5th gear changes
https://forums.pelicanparts.com/porsche-911-technical-forum/1094959-highway-5th-gear-915-a.html My reply then: I ended up doing just that in my 85 Carrera. I went to a 915 TL gear or the .724 (29:21) gear. I think it is perfect for highway cruising in the 75 MPH speed limit days. If I get down to 60, I pretty much have to downshift to 4th. 55 is the minimum speed for 5th on level ground and I usually just downshift. At 80 it is at 3,000 RPM and just sings along for mile after mile. Since I often do long road trips, I was willing to spend the money to have it put in. I still have my original 5th gear and would be happy to sell it, but there is evidently not much demand for the stock 5th. I did not drop the engine and transmission just to replace 5th. I just took the opportunity to open the transmission and replace some syncros and do a minor refresh. The TL gear is a little noisier, but the engine is a lot quieter. The stock 5th has a treatment to reduce noise a little. The TL gear does not have that.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Good point. His rears are 255 40 17... not sure how that compares in rolling diam but I think they are close to my 275 35 17
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Ivan I used to have 245/50/16 and since i could find them in Europe i went to 245/45/16 ..i could see the difference on speedo ... then again i am not an expert on tires maybe Bill will pitch in
PCA Member since 1988
Several of my comments are in the thread that Glen linked, and I agree with him. If you want a highway gear, go as high as you can on 5th. I also turn about 3000RPM at 80MPH and cruise easily in the 70-80MPH range. .
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Not really... 255/40/17 and 275/35/17 are actually fairly close in rolling diameter. Works out to maybe 2km/h difference at 100km.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP Last edited by mikedsilva; 05-21-2025 at 02:49 AM.. |
I'm thinking 2500rpm at 110kmh which would be a 0.69 ratio. But mostly 100kmh so I'm leaning toward the 0.72 ratio of 29:21. I'd be doing 2400 rpm at 100kmh and 2600 rpm at 110kmh..
2400 at 100kph sounds pretty relaxing to me.
Also, 100kph speed limits sound tragic!
'80 SC Targa Avondale, Chicago, IL |
yep, and they book if you you go even just 2km/h over.
With my 5th gear (TL gear or the .724 (29:21) I really don't like going below 60 MPH on flat ground. If there is a hill, I downshift. It would not be a good gear for a 62 MPH speed limit. I can drive 500 miles on one tank of gas while cruising at 75 to 80 MPH, AC cranked up to ice cold at hurricane velocity. Last summer I got to drive on Talladega Super Speedway. The track has a 33 degree banking and we were just cruising along at 125 MPH, AC on with my wife in the passenger seat. At 100 MPH I had to steer hard uphill as gravity wanted to push us down the hill. At 125, it was very neutral, and fun.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! Last edited by GH85Carrera; 05-21-2025 at 07:21 AM.. |
gearhead
It’s been a while, but if you go with that .68, be sure to ask Albins if it requires machining the tailcone. They also used to make a .65 and .62, which I’m sure require machining. I don’t remember about the .68, but they might still be making it specifically because it doesn’t require machining.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Agreed with Matt - a .72 has very little clearance.
Another data point that I've picked up running a tall 5th gear is the heat generated by this ratio. 75w90 mineral oil breaks down quickly if you do a lot of sustained 80+mph highway driving. There's a reason Porsche added trans coolers to the German spec (read: Autobahn) cars. I combat this with 85w140 GL5 hypoid oil (swepco 210 or Belray gear saver) and frequent changes (10-15k miles). Oil is a lot cheaper than a rebuild! Here is a box I just rebuilt that had a tall 5th that saw coast to coast road trips and rallies. The 90w swepco was a burnt smelling mess, with all surfaces coated in slime and the bearings were toast. This is a well cared for car with a fresh gearbox rebuild and tall gear added in 2022:
-Tony Instagram: @Pablo_the_Porsche | @RuchlosRallye AchtungKraft #002 |
