Zenith 40TIN Accelerator pump bar washers
Overhauling two of these carbs and on stripping I find that on one there are flat washers
between the acc/pump bar brackets and the carb body but on the other carb they are under the Allen set screw heads that secure the brackets which doesn't look right. Can't really tell from diagrams. Help would be appreciated. More used to Webers but find the Zeniths a bit of a learning curve!
Clive
Old 05-07-2025, 11:11 AM
