Transmission/Differential Free Play
How much rotational play should there be at a rear wheel when the transmission is in gear and one wheel is locked (on the ground)? To do the test I jack up one wheel, put the transmission in gear, release the handbrake and then turn the free wheel. On my 78SC I’m getting about 1.5" at the edge of the tire.
Old 07-05-2003, 12:11 PM
beepbeep's Avatar
Hard to tell, as you are also including freeplay in the tranny. With other words, differentiall could be brand new but you could be picking up gear-slack...
Thank you for your time,
Old 07-05-2003, 12:21 PM
You're right, but that's exactly what I'm measuring...total play in the driveline.
Old 07-05-2003, 12:53 PM
Irrationally exuberant
ChrisBennet's Avatar
Don't forget the play in 4 CV joints...
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 07-05-2003, 01:50 PM
Geary's Avatar
This amount sounds about right, but you can't really tell much from it.
Old 07-05-2003, 02:21 PM
It may be crude, but it's the only measure of total driveline wear. Have you got a better way of doing it?
Old 07-05-2003, 09:21 PM
Geary's Avatar
It isn't going to tell you if your ring & pinion backlash is the appropriate .006-.008" or double or triple that. So in that sense, it is of little value in measuring the most critical play in the driveline.
Old 07-06-2003, 10:41 AM
So how do you measure ring & pinion backlash easily?
Old 07-06-2003, 01:10 PM
Geary's Avatar
There is no simple method when the transmission is already in the car. However, a transmission builder might be able to get *some* indication of something amiss in an LSD-equipped car by draining the oil, dropping an axle, grasping the bare output flange, and lightly twisting back and forth.
It would be fruitless for a layman to go through these motions, as there is a fine line between overcoming diff bearing preload, feeling a barely perceptible backlash (and knowing the difference in feel between .006" and .012"), and then overcoming pinion bearing preload.
Old 07-06-2003, 03:21 PM
Non Compos Mentis
Every car I've ever owned has had about that much movement when in gear.
Old 07-06-2003, 03:44 PM
Thanks, that's the answer I was looking for.
Old 07-06-2003, 05:50 PM
Geary's Avatar
Old 07-06-2003, 07:23 PM
