Ambitious Outsider
sabeo.m's Avatar
Porsche Crest How I Painted My Fuchs (yes another DIY)
First and foremost I'd like to thank all the great authors who wrote threads on repainting your Fuchs, great inspiration!
This DIY project only consisted of my 16x7's, my 8's are practically brand new and didn't want to touch them.
First, I cleaned the wheels throughly using soap and water, towel dried and then I used compress air to blow off any dirt and dust.
The materials I used:
3M 400 grit sandpaper (wet & dry sanding)
3M 600 grit sandpaper
3M 800 grit sandpaper
Rust-oleum Satin black #7777
Rust-oleum Automotive Primer #2089
3M Blue painter's tape
After cleaning-before preparation:
Sanded using 400 & 600 grit sandpaper:
Primed:
At this point, the primer was sanded, the wheel was cleaned and then a few coats of paint was applied. The wheel dried over night before wet sanding.
Wet sanded using 800 grit sandpaper:
Re-taped and sprayed again-the result:
I'm happy with the result, I thought they were going to turn out horribly. I know these Fuchs aren't Al reed or Harvey Weidman master pieces, but they will do for now! Anything I could of done differently?? Thanks for everyones help!!
1988 3.2 Cab
2005 997.1 C2S
Old 07-19-2010, 03:15 PM
tonypai's Avatar
Looks great. Let me know when I can drop mine off. :-)
2001 Suburban - Tow Vehicle
2000 Miata - Race Car
1996 993 Carrera - Daily Driver
1981 911 SC RoW - Wannabe Race Car
Old 07-19-2010, 03:20 PM
Ambitious Outsider
sabeo.m's Avatar
Thanks Tony any time! I can't promise a turn around time LOL
1988 3.2 Cab
2005 997.1 C2S
Old 07-19-2010, 04:19 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Thumbs up I'll be doing it your way.
Great result.
While I had the wheel off for balancing, I did a quick test run (30 minutes, no sanding) to see if I would like the inside black.
Since I like it, I'll be using your list.
J.J.
Who Will Live... Will See
Old 07-19-2010, 05:04 PM
Ambitious Outsider
sabeo.m's Avatar
JJ, the inside of the rim black looks nice, are you going to paint the inlay of your wheels as well?
Old 07-19-2010, 06:47 PM
JJ 911SC's Avatar
Arrow Yikes...
Sabeo
... Which part are the inlay???
The section I did not paint in the first photo? Or something on the face?
J.J.
Old 07-19-2010, 07:05 PM
Ambitious Outsider
sabeo.m's Avatar
Quote de sabeo.m
Sabeo
J.J.
JJ, yep I mean the face of the wheel, I bet they would look good painted black with a polish lip...
Old 07-19-2010, 07:21 PM
JJ 911SC's Avatar
Arrow Great Idea
Yeah I could try that... Since they have varnish on them if I don't sand them the paint is removable quite easily.
So you would leave the lip as is. Actually since I like the B&W effect, the lip could be white.
If someone is good with photoshop, feel free to try it... on this pic.
Not to be picky but polish in the front and white in the black and we could do a survey
Old 07-19-2010, 07:36 PM
P-Car
woywitka's Avatar
Looks great, Just did mine today
Old 07-19-2010, 07:56 PM
Hodgey's Avatar
Primed:
You should have masked off the bowls where the lug nuts go......they will loosen as the paint wears away
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Ambitious Outsider
sabeo.m's Avatar
Hodgey, your right... I didn't think about that until later. I can carefully take a small flat head screw driver and scrape some of the paint out of the lug recesses.
1988 3.2 Cab
2005 997.1 C2S
Old 07-19-2010, 08:58 PM
Ambitious Outsider
sabeo.m's Avatar
Thanks, like I said-I'm happy with the result. I could have spent a little more time sanding, removing all the imperfections. When I'm ready for Perfection they will be sent to California.
1988 3.2 Cab
2005 997.1 C2S
Old 07-19-2010, 09:07 PM
hello fellow member
A good job done. Hours of hard work. Was the anodize removal done by you or done by previous owner etc. I decided on polishing the spokes but left the rough outer part bare. In the winter I spray WD40 all over the wheel to protect it from road salt pitting.
Now you've given me an idea, looking at your primer sprayed picture. I may have to get my centres powder coated in a satin grey cos it looks good. Thanks for the idea.
Old 07-20-2010, 01:26 AM
JJ 911SC's Avatar
Arrow I think I'm going for it...
Sabeo & all
I think I'm going with your suggestion and paint the inlay as well.
They have a some kind of varnish on them. Any body knows how to safely remove it.
J.J.
Old 07-20-2010, 01:49 AM
Ambitious Outsider
sabeo.m's Avatar
JJ, I would first do some research on what type of coating or varnish is on the wheel... But, my guess would be to use aircraft paint remover or something along those lines (?).
1988 3.2 Cab
2005 997.1 C2S
Old 07-20-2010, 09:19 AM
JJ 911SC's Avatar
Thanks. It'll be a winter project, summer is too short up here.
I'll be going as you proposed.
Old 07-20-2010, 09:23 AM
Sabeo, use your own advice and DON'T use a screwdriver !!!
Use stripper and a Q-tip
-Chris
My Fuchs can be seen here after getting a set of neglected wheels off Ebay......
"introduction" / one year anniversary
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 07-20-2010, 02:53 PM
Ambitious Outsider
sabeo.m's Avatar
-Chris
Thanks Chris, I'll try that.
1988 3.2 Cab
2005 997.1 C2S
Old 07-20-2010, 05:06 PM
I am going to start on mine. I’m glad others are using the same paint I have been using on some parts of my 84’. The 7777 satin black lays down perfectly. It’s great paint. And as my P Car is only a fair weather car it should hold up well on the Fuchs, as long as Prepped right. Thanks for this.
Jim D
Western Ma.
1984 -911 Targa
Previous owned 1969 911T
Old 05-23-2025, 02:35 PM
you lost me.
you had them primed..then you show photo of a 800 grit, sanded black rim...?
Old 05-23-2025, 05:28 PM
