I have an opportunity to buy a 1974 2.7 Liter 911 engine from a neighbor for $200. Is this a problem engine? It is partially dismantled but all the parts are there.
Thanks for your advice. Ron D
RonD 69912T |
GAFB
Buy it. For that cash you can make plenty of money back just parting it out.
Do a search on 2.7 motors. There are many problems specific to the 2.7 motors but the '74 is not susceptible to some of the worst stuff (like thermal injectors).
Several BMWs |
Yo, Ron, if you don't want it, Let me know, I can come pick it up!
Dennis H. 72 911E 2.7 RS stuff 72 911T with a 2.7(Sold 5-13-2011) 2012 Kona Blue Metallic Mustang GT Convertible 6spd 67 Mustang coupe future SVRA group 6 car 63 Falcon hardtop 302/4spd |
Hi Ron:
2.7 engines have had problems, but several owners are very happy with their engines. There should be several threads on the topic, usually started when a new or prospective owner like you asks. Here is the FAQ part of this BBS: http://www.pelicanparts.com/911/technical_specs/911_guthrie_faq.htm Good luck! Randy Detroit, MI |
I would. Yes the 2.7 is known to be problematic, but for $200 bucks you can't go wrong. A unrebuilt 2.7 usually goes for $1000 depending on its condition. My advice is to buy it, check to see if any head studs have been pulled. If they have then part it out you can easy make a few hundred bucks. If the block is fine the build an RS replica. If it has the MFI included then that alone is worth $1000. If it has webers that worth $1000. CIS, a hundred or so.
