Chain fence eating turbo
Which VDO or other aftermarket tachs are out there?
Have an old school 80's or 90's VDO drag racing tach and it's dying I believe in my '87.
Bought a new VDO tach, but it doesn't seat deep enough unfortunately into the dash to allow the blinker console clamshells to fit back around the steering column. The bezel collides and a real bummer as it looked so nice. Anyone found a nice looking, yet matching fonts aftermarket tach that goes to at least 8k RPM that is not tainted with the Porsche tax (shift light and signal indicators a plus)?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
SpeedHut appears to now offer gauges for our air cooled cars. Had their gauges in my previous LS2 Miata. Nice product.
Patrick
912E-3.2ss |
Thanks.
Stack is another option
Consider having the failing one reubuilt?
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
83 911SC Cab
AutoMeter has a wide selection in 5". Direct hook up and good acton.
May or may not fit with factory rubber sleeve. Simple solution to fit properly. ![]()
Are used stock tachs that expensive? I had John Bell (member on here) did one for me, and I have 2 others in a box, including a RUF tach. Benefit is these can be made ot look anyway we want now. Downside, the movements in some of them at sticky, etc and they are not easy to fix.
I also LOVE the Stack tach's, very rally car'esque.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
PCA Member since 1988
+1 on Speedhut. I have their gauges in another one of my cars and really like them. The tach has 3 lights to show when you are approaching your shift point or redline, and you can set them as you like. It can also record highest RPM reached.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
I’d assume the accuracy of modern tachs are better, too, but don’t know. Erroring on side of caution |
Makes total sense! I took have wanted a shift light for fun, another reason I like the stacks. I ahve a shift light module though by MSD, uses a chip to set the RPM and activates a red light. I will put that light above my tach to the right, maybe. My car is also a street car, and it’s light weight combine with the torquey 3.6 mean I don't need redline to be going pretty quick.
The green gauges are John Bell’s work, and the RUF tach I got from a friend who had an original RUF Slantnose, and this was a spare tach he no longer wanted. ![]()
