-   -   Help with O2 Sensor (http://forums.pelicanparts.com/porsche-911-technical-forum/1178522-help-o2-sensor.html)
KMoore68 05-31-2025 05:37 PM
Help with O2 Sensor
Hi,
I have a 1977 911 S that I have completed an install of Triumph ITBs with EFI with a MegaSquirt ECU V2 3.57
I am having an odd situation with the O2 sensor hookup that I'm hoping for some help with.
I have the Innovate controller wired to a 12 V switched power, confirmed with a multimeter and I have the Yellow wire on the controller connected to wire #23 (Purple) wire on the loom for the ECU, the black wire from the controller is connected to the ground on the fuse box I installed for the EFI install.
This is a brand new O2 sensor that has been run for about 30 minutes yesterday and was showing appropriate AFR readings. I replaced it because the original O2 sensor was showing the same behaviour and I figured it was bad.
Now when I turn the car on, the AFR is showing 22.3 the car off. I disconnected the controller and went through a re-calibration process. The controller is showing a solid green, and the O2 sensor is in free air (not installed in the SSI) and the AFR is showing 22.3 again.
I'm kind of stumped, any ideas?
Showdown 05-31-2025 06:00 PM
Maybe the controller is bad- check with the manufacturer to see if they have a bench test protocol.
