Help identifying some Fuchs
I took one off quickly to look in back they are pretty gummed up and corroded, all I could really make out is a 6x15 stamp, not sure if these are cheap replica or what, don’t look like flat sixes
Instagram: @TuitTech
Old 06-02-2025, 01:53 PM
Old 06-02-2025, 01:54 PM
You should see a date code stamped into the petal nearest the wheel size. Also there’s a part number and fox logo, also raised so should visible.
As for deep six style I don’t know.
Old 06-02-2025, 02:54 PM
PCA Member since 1988
Hard to tell from the pics, but it looks to me like you have a pair of 6x15 Fuchs and a pair of 7x15 Fuchs.
Take them off and clean the backsides enough to read the size and part number.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-02-2025, 10:21 PM
