Photo Request: Engine Wiring Harness
Hi Pelicans!
I am reassembling my engine and looking for photos and advice on how the engine harness routes over the oil breather plate. Below is where I am at, currently with my new harness.
Photos of a 911 from above with the CIS + intake off will be helpful to me. Thanks!
Mike
82 911SC Targa
Old 06-09-2025, 12:04 PM
Still here
pmax's Avatar
Shortest route on the other side of the breather next to cooler, to the tab on the front tin.
As a rule, embed as deep as possible under the airbox so it can't be seen.
Old 06-09-2025, 12:51 PM
Thanks for the help, pmax!
I took the air guide off to help resolve this issue and found that the new wiring harness to my alternator would bunch up significantly if i move the harness into this configuration. I am afraid it would get worn through or damaged if I left it like this.
Mike
82 911SC Targa
Old 06-09-2025, 08:42 PM
Still here
pmax's Avatar
Seems like looping it vertically inside the shroud would take care of the slack and not contact with the case thus avoiding any long term heat damage issues.
Can't tell for sure if you have one already, there's a grommet where it goes thru the shroud to prevent abrasion damage.
Old 06-09-2025, 10:15 PM
