nigel911's Avatar
BPR7ES okay to use in a 2.4T MFi?
Ordered BP7ES plugs and was sent BPR7ES's in error - understand the 'R' plug has a built in resistor - would they be okay to use in a stock 2.4T?
Just want to check before I install or send 'em back...
Old 06-26-2025, 03:42 AM
Yes, use them, non resistor no longer available
Old 06-26-2025, 04:41 AM
nigel911's Avatar
Cheers Ed, much appreciated.
Old 06-26-2025, 05:41 AM
They will functionally work, but you may suffer possibly two things. Radio Frequency Interference (RFI), and a less stable spark. Also could effect you CD Ignition System. Even a cylinder misfire. I never experienced a misfire, but even NGK talks about it, see like below.
Years ago, in the days of the dinosaur, when we ran non-resistor plugs, you would hear it in your AM Radio. Sounded like an audio tachometer. I recall you could hear a car next to you at a stoplight that was running non-resistor plugs. The same for plug wires. A good example of this is the Chevy Corvette, with its Fiberglass Body, that didn’t shield the radio antenna. So the used a shielded Distributor. A metal box fitted around the distributor cap. Later Air-Cooled Porsche engine used shielded spark plug wires.
Link to NGK:
https://www.ngk.com/what-is-a-resistor-spark-plug
Old 06-26-2025, 05:57 AM
