| Registered | Quote:
 I`d for with little torch and grinder ,once you have the one side off use puncher and it will come off Ivan
				__________________ 1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. | ||
|  06-26-2025, 10:01 AM |
| Registered |
			I just recently swapped out the hardware on my '84 exhaust. here what I used for anyone interested: Went with M8-1.25 x 40 mm. Class 10.9 Zinc Yellow Hex Head Cap Screw bolts - Amazon ID (ASIN): B007IAEDIA M8 x 16mm Flat Washer High Strength HV200 DIN 125A Yellow Zinc Cr+6 washers: ASIN: B0CVD5HHQW Self Locking Copper Nut: https://www.pelicanparts.com/More_Info/0009903250.htm?pn=000-990-32-50-M36&bc=c&SVSVSI=0580 Could also use these: https://www.ipdusa.com/products/11455/Copper-Flanged-Lock-Nut-CRP-11621711954-Volvo-946036-948645?srsltid=AfmBOopg8gahyW8rR5wwMCJ17gsb_Cl9v1Q XSCVtZCn-0Cl1CNjvX1aq
				__________________ TBD Prior: '84 911 3.2 Carrera, '83 911SC Targa IG: @heuersandcarreras "I want to use it. That's what 911s are for." - Richard Hammond Last edited by Matthew_VA; 06-27-2025 at 05:24 AM.. | ||
|  06-26-2025, 12:07 PM |
| Registered |
			Thanks Matt for posting the hardware too.  The links didn't work for me but I'll search for them on Amazon.  I will definitely need a lot of those. Yeah my exhaust manifold bolts are equally bad if not worse. I would have to drop the engine entirely to have enough room to work on all that. I'll try some heat, I have an air chisel where I may just have to try and slice through the nuts and drive them off. I got distracted trying to fix my door panel and waiting for the inductive heater to arrive from Amazon. I also appreciate the advice of not burning the house down, I'm definitely a fan of avoiding fire. I'll take some pictures as I go and probably come back to seek solace and deep breaths when I get frustrated
				__________________ 1987 Carrera 3.2 coupe 2014 R55 Clubman S | ||
|  06-26-2025, 01:56 PM |
| Registered |
			thanks for letting me know, replaced broken link with Amazon ID so can just search off that. Quote:
				__________________ TBD Prior: '84 911 3.2 Carrera, '83 911SC Targa IG: @heuersandcarreras "I want to use it. That's what 911s are for." - Richard Hammond | ||
|  06-27-2025, 05:25 AM |
| Registered |
			Just posting back--thanks to everyone for all the suggestions.  Here's what ended up working for me in order of increasing desperation.  I ended up using all the tools and learned a few new tricks using the air chisel. One method I found helpful was to use a sharp chisel to cut a slot in the rusted nut, then shift to the angle to drive the nut counterclockwise. I didn't have to split the nuts, but the slot was enough to quickly get many of the nuts to rotate. This was much faster than trying to cut off nuts that wouldn't yield to the heat and nut extractors.
 New exhaust is on and working great. I ended up filing out the rusty insides, grinding the mounting surfaces flat and smooth, and using stainless hardware and nickel anti-seize in the hopes that I will never get to experience this joy again. Here's a few photos. Again, thanks for the all the tips, it took some time but worked out well in the end.
|  08-05-2025, 11:28 AM |
