Help! Clutch disengagement issue.
-Took the engine out of low mileage, perfectly running 911sc for repaint Jan 2024
-Separated engine and transmission for engine stand, then sat inside dry shop
-No transmission work
-Reassembled recently, got everything working//running
-when reattaching clutch cable and adjusting, clutch pedal feels different, less smooth and more “stretchy”, and more effort required to press, especially at far end of travel (though it’s been so long since driving this might be normal, but doesn’t feel like it)
-when pressing clutch the arm on transmission is moving etc
-when pressing clutch pedal, it does not appear to disengage clutch
-shifting with engine running grinds badly
- starting on lift in gear, axles spinning, engaging clutch does not effect wheel movement at all (no clutch disengagement)
-adjusted the adjustment screw on transmission clutch arm to MAX clutch disengagement (fully screwed in) to confirm symptoms, no change, still grinds
-I have read talk that sometimes the clutch can get stuck on flywheel, which might cause my issues. Though the strange clutch feel I’m not sure is caused by the same thing.
Anyone had similar experience and have any recommendations or solutions??
Trying to avoid pulling the engine/trans again, but that may be the only option.
Thanks for any help!!
Old 07-26-2025, 06:17 AM
proporsche's Avatar
look inside trough the spy hole on top of the trans.if your fork is in the right place...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-26-2025, 08:45 AM
jmz jmz is online now
jmz's Avatar
Do you have any clutch pedal play? If not maybe you can adjust clutch cable a little more to get clutch to disengage.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 07-26-2025, 09:44 AM
proporsche's Avatar
good point..... JMZ
cozmos.................lets see your clutch adjustment --picture of the big arm
Ivan
Old 07-26-2025, 11:10 AM
Here a video of me pressing the clutch a few times
https://m.youtube.com/shorts/cyOiLimuyIs
Old 07-26-2025, 03:14 PM
Still here
pmax's Avatar
Remove the short arm and adjust it a few splines over.
It should look like the last picture in this post.
915 Clutch Helper "Omega" Spring Function
You can also try deleting the Omega spring action .... earliers cars make do completely fine without it.
Old 07-26-2025, 05:51 PM
Still here
pmax's Avatar
Another advantage is that you don’t have to dent that SSI just for the Omega.
Think about it.
Old 07-30-2025, 10:48 AM
Lash
Are you using the original clutch or has it been replaced? I know the SC's came with the rubber centered cone clutch. Heat and time will cause it to slowly disintegrate. My symtom was it worked ok cold but as I traveled down the road it was much more difficult to shift gears.
Lash
1963 356 T-6 Normal Coupe
1972 911 T Coupe ..... Sold
1972 911 S Targa ...... Sold
1980 911 SC Coupe Weissach
Old 08-02-2025, 12:08 PM
Targa_PB_78_SC
mike sampsel's Avatar
if you disconnect the cable, there should be a 1.2 mm gap between the positioning lever and the stop bolt, else adjust the stop bolt to get 1.2 mm. Then you adjust the cable with the cable housing lock nuts until you get a 1.0 mm gap between the lever and the stop bolt.
BareRearedRookie
Old 08-03-2025, 05:07 AM
It's entirely possible to have the clutch frozen to the flywheel ...
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 08-03-2025, 07:31 AM
Are you sure that the release fork is engaged into the t/o bearing?
206 637 4071
Old 08-03-2025, 09:05 AM
proporsche's Avatar
i did asked him , John;-)
Ivan
Old 08-03-2025, 11:31 AM
Ivan
and I noticed he did not answer.
Old 08-04-2025, 06:44 AM
proporsche's Avatar
yes - i know.. why are the op asking for help if they do not follow?
I just thought John overlooked my q ...that is all
Ivan
Old 08-04-2025, 09:04 AM
Still here
pmax's Avatar
It would appear Cozmos has ..... ahem.... disengaged with the thread as well.
Old 08-04-2025, 07:14 PM
Where did these flakes come from?
Old 08-05-2025, 07:21 AM
