Is this mount squished?
Is this mount cooked? squished? in need of a replacement?
1986 Carrera 3.2 Coupe in Grand Prix White
IG: @c.cal.porsche
Old 06-26-2025, 10:35 PM
Mounts aren’t expensive nor difficult to change so if in doubt change them (both)
Old 06-26-2025, 11:13 PM
This. It is easy to change, and not very expensive. If you don't know how old they are, and are worried about them, just change them.
Old 06-27-2025, 05:23 AM
That's fond- just deglaze
Hi ccallana- Certainly looks squished. As Glen mentioned, it's an easy change- here's a good string (I just replaced my mounts last year, as I was getting cap-to-base contact that I could actually feel & hear)
https://forums.pelicanparts.com/porsche-911-technical-forum/1081217-engine-mounts-replacement.html
Hope this helps!
Missed Approach
Petra- 1986 Coupe
Old 06-27-2025, 07:59 AM
Do folks recommend the regular ones for the coupe, or the harder cab versions?
IG: @c.cal.porsche
Old 06-27-2025, 08:21 AM
Hi ccallana- We may be getting into "which Oil is best?" territory here, but I went with the URO mount from our host, along with all new hardware. Very pleased.
Parts link:
https://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=911-375-043-00-M253#customReviewAnc
Missed Approach
Petra- 1986 Coupe
Old 06-27-2025, 08:27 AM
fallingat120mph's Avatar
I did the transmission mounts and engines mounts at the same time.
Might want to consider replacing all 4 at the same time.
If original might want to start soaking things with a penetrating oil?
Pretty easy job, find a thread, etc...
I would go with original or original equivalent supplier...
Erik
1986 911 Coupe
1986 911 Targa
Old 06-27-2025, 08:47 AM
and....if your doing it yourself be careful when removing the engine mounts as too much torque from things being somewhat seized can actually bend the engine mount cross member.
https://forums.pelicanparts.com/porsche-911-technical-forum/842276-recommendations-engine-mount-crossmember.html
I actually had to cut things from an engine removal, but knew I was going to get a new cross member (Rennline, sold here).
Keep us posted of the outcome!
Erik
1986 911 Coupe
1986 911 Targa
Old 06-27-2025, 08:50 AM
I found my cross member twisted slightly and with cracks. I had to cut the ends off it to get it out. It is a good time to invest in a new stronger cross member. I also did the motor mounts with the cab ones. As mentioned, it is a fairly easy DIY project if I recall correctly.
Old 06-27-2025, 09:20 AM
