Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
Special Tool
Is there a special 13MM wrench that you use to remove the Dizzy on an early (67) P-car. I was able to get if off using a short 13mm Open end wrench (barely) but I have a feeling I will not be able to get it as tight as I need to using it. I almost need a 13mm wrench with a 90 degree bend at the bottom of it.
What are you guys using??
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 07-07-2003, 01:57 PM
Dept store Quartermaster
lendaddy's Avatar
a 13mm wrench with a 90 degree bend in it. Seriously I heated one up and bent it. I also ground the box end thinner so I could get it in there.
Cornpoppin' Pony Soldier
Old 07-07-2003, 02:00 PM
Senior Member
Superman's Avatar
I know what you are asking. I make do with just a couple of different 13mm open end wrenches. Also, that nut does not need to be terribly tight. If it is at all snug, that's fine.
Mocha 1978 911SC. "Coco"
Thanks guys, That is what I thought but wanted to make sure I didnt spend too much time trying to find a tool that I did not need or does not exist. However, I do like Lendaddys idea of heating it up and bending it.
Superman, What do you consider snug? When I loosened it it only took a half of a turn with hardly any pressure to loosen this nut. Is that to lose?
Mark Scott
Vintage 911 Racer
Old 07-07-2003, 02:03 PM
Try a13 mm crowsfoot wrench on an extension to a ratchet. Jim
Old 07-07-2003, 02:07 PM
I saw those on the Pelican tools page. Looks like those will work.
Mark Scott
Vintage 911 Racer
Old 07-07-2003, 02:10 PM
Crow's foot wrench works a treat.
Old 07-07-2003, 02:25 PM
KTL KTL is offline
Schleprock
KTL's Avatar
A 13mm nut like the one for the distributor hold down is typically torqued to 24Nm = 18 lb-ft = not all that tight. No need to "gorilla" it. Snug is all it needs.
Kevin L
'86 Carrera "Larry"
Old 07-07-2003, 02:34 PM
pwd72s's Avatar
See your snap on man...they make a 13mm dizzy wrench. Also handy for reaching one of the heat exchanger nuts...mine works well...just ask RoninLB...he was the last guy to use it on a dizzy.
Old 07-07-2003, 03:53 PM
TSNAPCRACKLEPOP's Avatar
i leave mine loose for in flight adjustments.
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 07-07-2003, 04:14 PM
yep... a dizzy wrench is available.. and may work on the HE/depends on wrench..
my routine is a 13mm short flex head Snap-On.. Snap-On is shorter than S&K, Craftsman, etc. ................Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-07-2003, 06:01 PM
just loosen the 10mm nut on the outside of the clamp and wiggle out the distributor. the clamp and 13mm nut can stay put.
206 637 4071
Old 07-07-2003, 07:14 PM
