				lowering 930?
			i'm putting new wheels and tires on my 930 today and want to lower the front end. i know the two nuts that have to be turned, can anyone help mke on which way lowers and which way raises the car? any one know about how many turns equals about one inch lower?? thanks so much!
				fastlos 86 939 powerhaus stage 1 68 amx 390 97 gmc z-71 vortec
	86 930 Powerhaus Stage 1 W/SC Cams Billstein Sports Weltmeister Torsion Bars & Strut tower brace Kinesis 9 & 11 K-28's Lowered Balanced "Scary Fast" 87 BMW 735I "Kid & Grocery Hauler" *68 AMX 390 Go Pack 4-Speed "Burnout King" *82 Honda Trail 70 "Just Fun" *Future Cart Champion Son, Mateo "Go Da Da Posha Go Trbo"  |
			I think one turn is about a 1/4", so if that is correct then 4 turns would give you an inch, but I'm not sure which direction is which.  This has come up several times in the past, you may get some info from a search on lowering
	Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa    SOLD 2004 - gone but not forgotten
			Counter Clockwise will lower the car.  It relieves tension from the torsion bar so the car sits lower.  Keep in mind that 1 turn does not equal 1" exactly.  It depends on how low the car already is.  The lower the car is the less you need to turn it.  You also need to measure the back of the car.  When you lower the front, the rear will raise slightly.  It is a real art to get one balanced once you start playing with it.
	Good Luck!!!  |
			so...one complete turn lowers the car 1" or 1/4"?? anyone clear on that? thanks so much for your help!
			fastlos
			It is 1/4" but that is only relative to the spring rate.  The point I was trying to make is that the lower the car is the more impact one complete turn will have.
